I love this pic........................... :rofl2: !!!
Anyways.............update of whats planned in the near future.
> Repaint the front lip
> Clean the insides of the other 3 rims
> Keep saving for work meisters
@landscribble.....come to think of it now James (10 4) did mention you ages ago in one of our random car related chats.....and yeah I often drop and pick my sister from uni so that would explain it.
Update:
Work roster is hectic (lots of people on leave at the same time - slackers!!) and coupled by the fact that I am saving for the rims now car stuff has been put on the back burner sadly.
Did however pick these up yesterday (enough of struggling with miniscule rachets)......and plan to spend a couple of hours on my days off scrubbing my current rims till they are squeaky clean !!
  • 4 weeks later...
Not a lot has happenend........................
Had a squeaky clutch pedal......................two sprays of WD40 and that was nipped in the bud.
Went down to Barbs this morning with the lads.........lovely sunny day and some nice rides.
Doing some touch up paintwork this arvo......window wipers getting a touch up and the rear bar corner.
In other news.............I might be getting a bucket seat soon............................. :yes:
you bought WD40! haha
^^^^^ :thanks:
Today is seat day.....
First up....I highly recommend a GTR seat.....works wonders.....I am so snug in it now its not funny.....its comfortable yet firm....holds you amazingly well yet is easy to get into and out of....and yeah bolts straight in so no dramas.....fifteen mins and I was done (with the fitting it in I mean)
HOWEVER.........................................being anywhere between 15 to 20 years old these things can get a bit "rugged, tired, worn" etc.
Started off with something like this..............(didnt take a picture so stole one off the internet)
Took the old seat out (remembered to take off the seatbelt sensor plug)
Then "attempted" to put the old leather covers on..............
For those of you who have seen a GTR and a GTST seat you will know that while they are similar in design the top bit is totally different.....the GTST having a separate head rest.
Time for some innovation...
There was no way I was going to leave it like this.........................so I put on my thinking cap and called in backup
Does this ring a bell........................
My car is called "Night Fury" and for those who have not seen "How to train your dragon" this is what its named after
Well so did a little bit of this....................................
and then "backup" did a little bit of this....................
and then I did a little bit of this...................
and then a bit of this.....................
A BIG THANK YOU..............because you are amazing !!
This is how its going to be for now.......................before I put in some big bright yellow and black eyes sometime tmrw possibly.
:wub:
Will post finished pics when I am done
^^^^^^^ I would say so myself...hahahaa...and :thanks:
Made the eyes this morning............
Then glued them to a leather backing that I carefully cut to the same size......put bits of velcro on the back and hey presto...we have ourself some eyes.
Ok....im working on something and the bloody front grill clips are a pain in the ass :angry: Feel like just wrenching it off :rant:
Also....................I am painting the bootlid badge...and its looking good :P Pics to follow soon
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
