2011 JDM Fest will be held on the 19th of November at Ultimate Tunes Phillip. The event will kick off at about 9:00am and run throughout the day, With a dyno competition, Show and Shine, and a Sound off. The awards for the Dyno comp will be, Most powerful FWD, Most powerful RWD, Most powerful AWD, Most Powerful 4cyl, Most Powerful 6Cyl, Most Powerful 8Cyl, Most Powerful Rotary, and Dyno Dominator, The Show and shine Awards are, Best Paint, Best engine Bay, Best Interior, Peoples Choice Award, King Of JDM Fest. We also have a range awards for the Stereo Sound Off. The Event is prodly Sponsored By Shannons Insurance, Racing Ready, and Ultimate Tunes.
https://www.sau.com.au/forums/topic/377500-jdm-fest-2011/
  • 1 month later...
