For sale or swap I have a complete R34 GTR engine. It is complete from intake plenum, turbo's and dumps, and block to sump. Engine mounts are included. I have a 2 genuine R34 front pipes here too if needed. No power steering pump or AC compressor.
The engine has around 95,000km on it, and was removed when I fitted my RB315DETT. I have bolted the engine into my engine test rig and will compression test and hot run it if anyone wants to see it run.
I can arrange freight to anywhere no problem and can mount the engine to a pallet for transport.
Asking price is $8000, not including freight.
The reason I am selling is that I am preparing to build a version 3 of my open deck engine, and it would be a shame to disassemble a perfectly good engine and then overbore a virgin 86mm bore R34 block, and then have to part out the parts I dont need.
So, for swaps here is what I am after:
At least 1 R34 GTR block and R34 sump with ALL the accessories. So that is the (original cradle, main bolts, water fittings, oil squirters, AC bracket, engine mount stalks, power steering bracket, turbo oil lines and all the coolant hard lines). I would prefer the sump already have a high octane or racepace extension welded onto it.
Next is the cylinder head. Specifically I am after a bad ass RB26 ported head with R34 spec cams running at least 10mm lift, step 1 springs and 260-272 duration (no larger). The heads must be complete, from plenum/throttle bodies thru to the exhaust manifolds. I need cam covers, idle control valves, cam sensor, all the hard lines, rubber breather hoses, the works.
I will also need a sets of cam gears (os giken, tomei or trust).
If you know any workshops that have what I need lying and would like to have a good spare motor in exchange, please pass on the word.
Call me on 0434 147 478 if your interested in making a deal, or prepare a detailed list of what you have and PM it to me.
I'll put up some pics tomorrow and have some compression test results by then as well.
Cheers,
Ian.
Hot ran and compression tested the engine today. Results were all 155-160psi.
Pictures and video attached.
http://www.youtube.com/watch?v=-9zoaiio9g4
The engine is running rough but the main thing is that its running on all cylinders. The rough tune is because I had to build a base map from scratch, and it is only tuned by ear. I havent got a wideband sensor on the test rig at the moment as it is in someone elses car.
Call or email me if your interested.
I can attest to the condition of this engine. it's my old car and was standard it's whole life in japan. I bought it with log books etc in japan from a mature owner. it was standard right down to standard boost, standard exhaust etc. 100% no mods at all and always serviced properly and on time. certainly has plenty of life in it yet. :)
+1 saw this is the flesh when I dropped off the RB26 bottom end to Ian so he could start his RB31 stroker. The whole thing is immaculate.
Will be a very good pick up
  • 1 month later...
would you take 6 grand cash? and are they steel wheel turbos?
No thats too cheap. Turbo's are standard ceramics.
With the exception of the power steering and AC pumps it is a 100% complete engine. From intake plenum to front pipe, cam covers to diff.
Hi Ian, you rolled all the way from Cairns to SAU Nats in Shep and back again.
You could have at least bought this RB26 down and put a for sale sticker on it ;)
Alas there was no room in the car for a second engine. I would have liked to take back a few engine blocks for the next project too, but the boot was full.
Im impressed you drove all the way down from cairns to Shep, took your car out on the track and drove all the way back to cairns. Now thats a skyline enthusiast !!!
If I was still contracting I'd buy your 26 and drop it in my GTT.
  • 4 weeks later...
Thanks. Funny thing is I nearly missed the track day, having slept in by mistake. I was a little tired after the drive down !
On to Business. Bump! The engine is still up for grabs.
BUT! I am now accepting offers for the internals. I will consider removing the head and sump, and selling just the block and internals if someone needs a quick repair for their blown up R34 engine.
Alternatively I am prepared to strip it and sell the internals off seperately. I don't want to start breaking it up until someone takes the crankshaft though.
Up for grabs are:
R34 Crankshaft $1200
Standard Harmonic balancer $200
Rods + Pistons $500
Standard oil pump $200
Standard turbo's $500
R34 GTR Dumps $200
R34 GTR Standard front pipe. $100
Regarding pricing for these parts, I am negotable and especially interested in part swaps as part of the deal. Just PM me (don't post your offer in the thread).
I am keeping everything else with the intention of building the next version of my open deck engine. But If someone needs a virgin 05U R34 block and has an un-cracked block with light bore damage (or 3) I'll consider a swap. Im pretty keen on keeping the genuine block though, so the original serial numbers will match what was in the car from factory.
That is all.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
