few things
Autos drain more power (which i asume is the most important thing) than manuals as there is fluid coupling until convertor lock up... compared to an engaged machanical clutch giving direct drive..
trimatics are sh*t, even most built ones
if you do put a built & manualised auto in with a higher stall (which u might want if your putting a gt3540 on a rb25) you would want a proper trans cooler... & diff gears if ur real serious...
if its manualised u still have to select the gear anyway...
why not just put an r33 auto in it? saw one sell on ebay for like $400...
what bout speedo do u care if its out.. or works at all?
perfect thread below for u
http://www.skylinesaustralia.com/forums/topic/349853-vl-auto-or-t400-gear-box-for-r33/page__p__5644301__hl__r33+speedo__fromsearch__1#entry5644301
I went through all this not long ago, rebuild a Jatco that will only last so long. Find a ecu that will control it and so on. I ended up putting in a powerglide so i could choose
whatever ecu i wanted. Bought the parts to rebuild it from Summit racing and you will have a box that will last.
Herein lies the problem. I called up a local tranny shop to find out which older domestics dont use a computer similar to the R33 autos but that still has O/D for daily driving, turns out there arent that many. My choices would be Ford AOD or Chevy 700R4. Upon researching them, I discovered that neither has a removable bellhousing, which leaves them out (I'm assuming the easiest way to do this is build a bellhousing adapter and use an R33 bellhousing, which I have in my possession). I'm now leaning towards a ford C4 like so many others have done.
few things
http://www.skylinesa..._1#entry5644301
Why not R33 auto? I'd love to, but I can't find any solid info on shift kits, manual valve bodies, trans brakes, control needed, etc. It needs to be able to stand up to 300 rwkw hard launches too.
Thanks for the link :) .
there is an r34 gtt in QLD with a R33 Rb25det stroked to 2.7 full built with a T88 33d making 490rwhp.. it uses a 300zx 4 speed auto with a manualised reverse pattern valve body and like a 4400rpm stall convertor (i think dont quote)... seems to be doing ok... also got nismo 2way & gtr cvs...... maybe check the 300zx auto out.... i really like that car too except for the auto.. being a fan of manual and all nyaanyaa.gif....
if you are going to do it i reckon check all the nissan stuff until its gets too pricey then go c4 or t350 in my opinion..... but all that other Sh*t i mentions would still apply...
Edited by PaulosECR33
It looks like luke and gtsboy still are stuck in the mindset that auto cars are slower and you need a manual to pushstart it. Well here news boys. Auto's are quicker!!! Line up an auto and a manual with the same rwhp and the auto is quicker. Haha you both FAIL and the fact that you comment as you have in public makes it so much more FAIL. Haha anyway just a lighthearted dig. No need to cry about it. I'm sure this little vid will make yous happy again. Lmao as if I give a f**k about what anyone says....ooops I just pissed myself laughing blush.gif
http://www.youtube.c...h?v=h5oWX06iXbI
There is only one problem that can be encountered from that setup.....he will have ford parts on his car. May as well drive the thing off the edge of a quarry right now.
I have a C4 in my R33. Nothing wrong with ford parts when they are built strong...
u could say a manual is quicker than an auto.. and vice versa there are so many variables though... i bet you a car equiped with a quafie or holinger sequential box would destroy lots of automatic cars but then a car with a powerglide & 5k stall fall manual blah blah blah all the crap would destroy most normal manuals on the street but that is extrene ends of the scale and the truth is not many ppl have them.. i would have to say out off the modified street car scene in aus the autos would be quicker in a drag race ( will probably get in trouble for saying that).. but i also have to say that drag racing on the st doesnt mean Sh*t ... i kno what id prefer... ill take Black spur, arthurs seat or great ocean rd in my quafie over a hectic drag at princess highway ANY DAY.
Don't be a wankstain. Auto cars are bloody boring to drive. Not to mention the risk of your sister (girlfriend) accidentally kicking it down and gaining 200HP in 0.5 sec and spinning it off into a tree. But seeing as most of you juvenile late term abortions can't drive anyway, I would guess that you'll probably put it off the road yourself and then blame the sister (girlfriend) instead.
Who gives a shit whether the cars are faster in straight line? If all you're going to do is put your foot flat to the floor and hold on, then you might as well not get out of your PS3 buck in the lounge room.. you'd be a hell of a lot safer playing GT3 than being out on the road with the rest of us anyway. (Safer for us, that is).
Clown.
Have you driven a modified auto..? I cant see how they are boring. Mine you still need to put thru the gears (like a manual) but I dont have lag between gears so its a little more lively than a manual when on power.
The only thing I cant do is clutch kicks to get wheelspin.
Each to there own on manual/ auto setups. How boring would things be if everyone had the same setup...
:cheers:
:cheers:
Hey mate I'm sure if that's your car specs in your signature you don't need a clutch kick to get wheel spin. P.s my wife went to uni in Launceston and I lived in Hobart for a couple of years before we moved to Perth. The roads here are no where near as good as Tassy and the air is no where near as cold. And there is no tele with cheap steins on a wednesday either.
Yep thats the power its making. Will be more soon with a few more psi.
Bloody oath mate. I'm putting a genuine garrett gt3582r with a 6boost manifold on my r33 gtst early next week. I have supporting mods to tune it to wherever. It will be held back by the fuel pump which is an intank walbro good for 255 lph and stock internals. Should have it on the road by next weekend. It will be a pleasant change from 200rwkw biggrin.gif.
Back on topic.
I'm really trying to decide what route to take. It seems it will cost me at least 3k (and prolly a few years off my life lol) to properly adapt a c4 to the back of my RB. The pluses are I live in Canada and the parts for these units are a dime a dozen and if I didn't like the auto I could at least sell the build tranny to recoup some cost.
If I go R33 auto, It can be had for dirt cheap, but parts and setup will be a royal pain. I still have not received any concrete pricing or what is needed to make an R33 auto drag-ready.If I want to get rid it, it might be hard to sell over here.
Edited by ST240
I got my C4 from Protrans and it was ready to bolt onto the RB block. It came with a yoke to suit the box and had to modify the tail shaft to fit a bigger uni joint to suit the C4 yoke.
Made a new gearbox cross member to use the original mount points from the manual setup.
Im running a transbraked C4, 3800 stall on my 26/30
Have a look here on the Protrans site.
http://www.protrans.com.au/ford_c4_c10.htm
http://www.protrans....ford_c4_c10.htm
I saw that. How much did the setup cost? Hows that 3800 stall on the street?
Cant remember the exact price but I think the change over to auto was around 8k, with shifter, transcooler, lines, convertor, flex plate. etc
From the few times it was driven on the street it was great. Way more fun to drive than a manual. Its been off the road for a while getting a new engine build so will give it a good work out soon
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
