If I pull the head off what would I be looking for? Like detonation and symptoms? Cheers, also it's hit adjustable cam gears etc, can these parts be salvaged for another rb?
um...when you say its hit adjustable cam gears....what are you meaning?
Given cylinder 5 has 0 comp and 4 has only 15psi there is no way on this side on gods good green earth you will be putting those pistons backin with just new rings, if your lucky you will be able to bore out the damage at 40thuo either way at best you will be up for over sized pistons rings HG etc etc, and really why would build a motor and not pay the extra for forged items, suddenly $1500-$2000 for a good condition motor will be cheaper and then can be resold once forged motor built
My last 32 motor had 30psi in cylinder 5 and there was 1cm of the ringlands just gone and a scratch on the bore that wouldn't come out, my guess to get 0psi then he has had the piston and valve come together
Also the fact that he asked if the cam gears can be reused is a sign he is a complete nooob, so another reason why a rebuild would be a bad option.
Noob to skyline scene, yes kind of, I have previously owned a na r31,
I'm not really interested in doing any machine work to this engine at the moment as cash is tight, thinking I'm just going to drop in a wrecker for now aslong as I can find a decent one, as for a rebuild I was wondering iffy adjustable cam gears could be damaged at all from the engines current issues? Yes I'm a noob but I have worked on a lot of cars and as it's a daily drifter one day dedicated, I've been looking into building a 25/30, if my top end just needs a rebuild. But all with time to come, I'll get some pic's up as soon as I can. All the suspensions set up already it's just the engine left
I had a similar issue years ago and it was a f**ked couple of gaskets. Check for leaks
Do you remover anything specific? A mate has a r33 gtr and reckoned it at popped a couple valve stem seals, if it had could this cause low comp?
Before jumping the gun, pull the head off and take a look, it could just be the head gasket blown between 4 and 5 which would explain little to no compression between 2 adjoining cylinders.
If Head gasket looks OK around the sealing ring, look at the bore, if that looks OK start pulling pistons and inspecting them.
Ok will do and I'll grab some photo's to report back,
Quick question guys while I was pulling stuff to get the head out I noticed my rocker covers are held down by Phillips head screws? I've done many gasket changes before but never have I seen Phillips head screws used for any particular part of an engine besides clamps etc, are rb's like this standard, I wouldn't imagine so but not 100% sure, I pulled the paper work I got with it and it's say all the bolts where replaced at a shop in seven hills, but why would they use Philips heads instead of 8mm hex heads for the rocker covers?
  • 1 month later...
Okay guys taken some time but have finally gotten around to pulling the head off today, all the pistons except for 3 look in decent condition, 3 has marks on ether side of the piston but no visible marks to the bore, all the valves seam to be fine haven't pulled them put to inspect yet tho. I'll try post some pics up
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
