hey guys,
Got a oil leak on the front of the motor around the oil pump and all up the face of the block. At the moment it looks like the cam covers leaking oil and running down the front of the motor(am in progress on changing them now)and filling up the cupped area on the pump. BUT im also thinking it maybe the front seal as well. How hard it it to change or is it worth just putting it into the motor mechanics and getting them to do it if it still leaks after fixing cam gaskets.
https://www.sau.com.au/forums/topic/378066-changing-front-seal-on-rb26/
you'd wanna make sure it was actually leaking and at a rate that bothers you before you go to all the effort.
if you know your way around the engine bay all you need are some tools and engine manual (pm me if you need a copy) and you should be fine.
got no problems with doing the work, only thing is getting the harmonic balancer off but can make something at work to do that.
pretty sure is the cam covers making the mess as was alot of oil down the side of the block and think some has been sucked behind the timing cover by the looks. belt was changed about 50k ago so half way through its life.
will have a look at the cam seals tomorrow but dont think they are the problem either.
I have a manual as well, thanks for the offer anyway :thumbsup:.
not sure if ur aware of it mate but the allan key bolts from the cam cover match the thread of the two holes in the balancer. So if u end up making some sort of puller u can use those by just throwing some washers on the end of them. Though depending on how tight ur balancer is on there u may end up stretching the cam cover bolts so try get a hold of some yeild and spray the hell out of it....
Radiator will have to come out if ur goin to use a puller so u got some room....
thanks for the heads up Joe, will get some ss or high tensile ones from work.
got the motor back together now, just seeing if the oil will subside otherwise will pull the front down.
how hard it the bottom timing belt gear to get off??
already been to nissan and got the part number, cost about $31 i think. such alot of work for a little part >_<
they vary a lot. i pulled my rb25 timing gear off with my fingers, just slid straight off. then i needed a grinder to get the rb30 gear off, was fused to the crank. if its that bad you can try drilling and tapping it for a puller or you can cut it off like i did and use another one. i have a spare if you destroy yours :pirate:
have decided to give it in to my tuner now, got something wrong with the new tune i just got with the car not starting straight away and running like shite so he can look at that at the same time. damn cars :domokun:
Gunna have another look tomorrow to see if the cam seals are gone. Oil seems to be still coming from high up ( clear cam cover ). So going to remove top and bottom cover, clean everything, connect everything up and run it to see where its coming from.
Wouldn't think it would go above gasket line. Maybe I'm wrong
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
