  • Replies 68
at last count the car was on sale for 90k, altho this was before the Nitrous was added... so we shall see...
Shan, The car was never on sale for 90k. A lot more than that has been spent on the car so figures are a bit blurry.
The car is for sale though and I have a number in my head which I'm asking for it.
If anyone is interested, drop me a PM and we can talk.
Here is the graph from MAS for ya.
Enjoy.
my bad dave, coulda sworn last year at autosaon you told sum1 you wanted 90k, but that was a good year ago lol... time to start doin up your euro no :D
You are absoulately spot on summoner,
For a national event of this magnitude, it's a piss weak effort to hire a dynolog, especially if the software is limited to 200kph.
Needless to say, big hp cars are big hp cars, it just make it harder to compare the results.
i think it's got more to do with which garage the organisers are good mates with rather than stict adherence to uniformity across the board. If Cabin were smart, they'd invest in a Dyno of their own (seeing that they do up to 7 shows a year not including semi's and finals). This would be ideal to take on tour with them.
Also quick question bout the Dyno Dynamics dynos... don't they need to be secured to the ground using underground bolts or something? Coz the one at MAS wasn't really secured to the gorund that well (and it couldn't have been because it was in the exhibition centre.
You and your .1 You do realise that for that 0.1 to mean anything you are talking about the dyno being accurate to less than 0.0167%!!!!!
:D:P;):) :)
That's what makes it so funny though!!! :rofl:
Emre! We are talking about car people here!!!
I mean every time I hear someone talk about an HR32 GT-R I want to stab them!
If that isn't being serious about a trivial detail then nothing is!
I am probably a bit too much of a tourist in this forum to pick up on in-jokes thought...
I think the most impressive thing about this car is for how long it has over 400rwkw!
Look at the meat in that graph - it's pretty easy to see that it isn't just a dyno queen!
Go Leewah - Go Fangartists! :D
matt
He heee...
Being serious about a dodgy dyno printout is a little contradictory, don't you think...? :P
I think everyone with half a brain figures out it's dodgy and just a joke within 10 seconds of seeing the dyno chart ;)
It's not meant to be serious, it's all in good fun :D
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
