Has anyone fitted 19 x 11 wheels on a R34 GTR?
I've been offered a set as an alternative to 19 x 10 but can't really find much info about wheels that size :)
19 x 11s have an offset of 25 & the 19 x 10s have an offset of 15 - so in theory they should have the exact same stance, so should sit right?
https://www.sau.com.au/forums/topic/378587-11j-wheels/
You may have to 'adjust the inner plastic guards if the tyre rubs, especially if it's lower than stock.
Also depends on what width tyre you decide to run. 34's are pretty accommodating for bigger, wider wheels.
Mine are 18x10.5 +18 and 275 width is stretched.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6038180
did a quick search and found this if it helps? http://forums.nicocl...34-t288174.html spec sheet is down a little bit
Yeah seen that a few nights ago and got in touch with him :thumbsup:
He said they only had to trim the rear liner a bit to get them to fit comfortably :D
Quite excited now about recieving mine :banana:
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6043411
I finally got some tyres fitted to these today & I can now confirm that a 295/30/19 on a 19 x 11 ET25 will NOT fit on a R34 GTR :(
They fit perfectly & look amazing - unfortunatley the car is undriveable as on even partial lock the inside of the wheels are knocking against the suspension :(
I'm hoping to get hold of some 5mm spacers & see if it pushes them out far enough to avoid the arms
A couple of pics of them fitted though, stock wheels have been refitted now though while I search for a solution
Ignore the white tyre fitting crap around the wheels, I need to give them a wash :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6063264
They look massive diameter wise in that picture.
How much do they stick out now with the 10mm?
Drive it over bumpy areas and see if it scrubs on the outside/guard.
19x10.5 +12 and 15mm spacers were scrubbing on the rears. Left a nice thin cut all around my tyres.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6066996
With a 10mm spacer it sits pretty much flush with the arch.
There will be some rubbing, especially once lowered. I think it will be a case of rolling the arches or possibly even Z-tune arches to give a bit more clearance :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6067536
damn, pity I didn't see this thread earlier, could have warned you off them...
Anyway, for people searching in the future, I'm running 18x11 +18 and they touch the suspension upright before full lock, so not ideal. I'll probably try and get some 5mm spacers to just get them out far enough to clear, but they're pretty much flush with the guards as is.
Does look good though.... :D
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6072919
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
