Has anyone fitted 19 x 11 wheels on a R34 GTR?
I've been offered a set as an alternative to 19 x 10 but can't really find much info about wheels that size :)
19 x 11s have an offset of 25 & the 19 x 10s have an offset of 15 - so in theory they should have the exact same stance, so should sit right?
https://www.sau.com.au/forums/topic/378587-11j-wheels/
You may have to 'adjust the inner plastic guards if the tyre rubs, especially if it's lower than stock.
Also depends on what width tyre you decide to run. 34's are pretty accommodating for bigger, wider wheels.
Mine are 18x10.5 +18 and 275 width is stretched.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6038180
did a quick search and found this if it helps? http://forums.nicocl...34-t288174.html spec sheet is down a little bit
Yeah seen that a few nights ago and got in touch with him :thumbsup:
He said they only had to trim the rear liner a bit to get them to fit comfortably :D
Quite excited now about recieving mine :banana:
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6043411
I finally got some tyres fitted to these today & I can now confirm that a 295/30/19 on a 19 x 11 ET25 will NOT fit on a R34 GTR :(
They fit perfectly & look amazing - unfortunatley the car is undriveable as on even partial lock the inside of the wheels are knocking against the suspension :(
I'm hoping to get hold of some 5mm spacers & see if it pushes them out far enough to avoid the arms
A couple of pics of them fitted though, stock wheels have been refitted now though while I search for a solution
Ignore the white tyre fitting crap around the wheels, I need to give them a wash :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6063264
They look massive diameter wise in that picture.
How much do they stick out now with the 10mm?
Drive it over bumpy areas and see if it scrubs on the outside/guard.
19x10.5 +12 and 15mm spacers were scrubbing on the rears. Left a nice thin cut all around my tyres.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6066996
With a 10mm spacer it sits pretty much flush with the arch.
There will be some rubbing, especially once lowered. I think it will be a case of rolling the arches or possibly even Z-tune arches to give a bit more clearance :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6067536
damn, pity I didn't see this thread earlier, could have warned you off them...
Anyway, for people searching in the future, I'm running 18x11 +18 and they touch the suspension upright before full lock, so not ideal. I'll probably try and get some 5mm spacers to just get them out far enough to clear, but they're pretty much flush with the guards as is.
Does look good though.... :D
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6072919
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
