Item for Sale: 1989 Nissan Skyline Gtr 32 Description: Cleanest 32 GTR u will find Location: Crestmead QLD 4132 Region: QLD: Brisbane South Odometre: 110,000 kilometres Asking Price: $16,000 ONO
Condition: Used Reason for Sale: Need a change Delivery Methods: PickUp Contact Method: Telephone [click to view]0406635400 Extra Information: Hey guys im selling my well loved toy one of the cleanest GTR's Around
and for the money im selling it for well worth it
Pretty much stock with a power fc running it 304hp at all 4 wheels
so no slacker
Volk 17's x 9 all round
tein shocks all round
masive exhaust sounds sweet
major service done
Im only open to trades if its a jap car
Some things in side carbon fiber wraped and front lip done to
have dyno sheet for the 304
4 doors welcome
https://www.sau.com.au/forums/topic/378646-stand-out-32-gtr/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
