Hey everyone,
Got an issue with the GTR, curious if anyone else has had the same...
On low boost I was loosing oil pressure..... it would drop from 5-4 bar when giving it hard on gate pressure.... now I took to a shop and I got a Mechanical gauge on it..... we topped up the oil as it was low.. and now it only looses pressure on high boost where it drops about 20 psi... I am hoping this is not a engine out job, but assuming pump, or engine damage the engine runs fine as it is... So I dunno seeing as its only on boost I am hoping its just a turbo issue....
It is fine Free revving, No engine noise, oil pressure is fine, no smoke... the night before I had 2 intercooler pipe blow offs when I was on the 2 step at willowbank.... assuming this caused it.
There was a fair bit of oil in the cooler pipe not sure if turbo is ok, checking it tomorrow.
Has anyone had it where the oil pressure has dropped on boost?
https://www.sau.com.au/forums/topic/378802-oil-pressure-drop-on-boost/
  • Replies 69
You got an aftermarket sump baffle, not the stocker...
My old car would drop off when accelerating in the first 3 gears. Only had a stock sump baffle.
My aftermarket oil pressure gauge showed the drop, and that was with 5l of oil in the sump.
After that I always put 6litres in every oil change in GTR's and that seems to stop the problem, before it's too late.
When I had the 26 apart, I measured how much oil you could put in the sump without it getting whipped up by the crank.
6litres fills the sump to the brim. When the engine is running a certain amount is in circulation (in the oil galleries, oil pickup, head, turbo's etc) and it ran with no dramas. I had done that for years, and also do it to my 34. Never killed an engine, just gearboxes!
The oil I use comes in a 6 litre container so no problems for me :)
Another point, the stock oil pressure gauge is not quick enough to tell you that you are losing oil pressure for those few brief seconds, when it does it's definately too late! spin a bearing anyone??
Cool stuff.... cheers for the info
Just found a massive thread on the forum where the general concensous is to over fill by a litre which would take it to just under 6L...
what oil do u buy that comes in 6L btw?
How much power do ur 26 have and how often did u give it some stick?
Edited by GTR_JOEY
No worries!!. I just run nulon 10W40 and change it every 5000km or less. Also run a relocation kit and oil cooler.
See my sig for the 32.
34 is currently on 294 all wheel kw, with more soon...
It's mostly cruising, with the odd twisties thrown in with 7000RPM plus sometimes.
Big thing is servicing and keeping the little things in check with these cars.
Do you drop the oil in the oil cooler as well, when you do your oil changes?
Yes I have....although I think it was load, not boost. I spun a big end bearing shortly after. seriously.
I dont like that idea :( lol.
Stock baffle. I am going to try the overfill idea, hopefully that solves the problem but yeah... do you know what causes it?
My Rb26 is rwd and it surges like a bitch if you fill it to the normal H mark on the dip stick, so I for you guys with a little more grip of the awd, it would obviously be worse.
When I fill it with 5.5L it sits just above the H itself on the stick, but it still surges a bit, but I think it should be ok for normal street duties....Track will definately use 6L.
EAT26...Does it drop only on hard accel.? Or does it do it too when already in motion and bringing up the revs?
Ccome sunday we will sort it out my mang
:thanks::3some::wub:
Its dropped only when Highboost at 21psi is introduced and drops 1 bar on the internal gauge.
Your not flooding the head are you? This would lower the sump level and could cause issues with surge? More oil may not help if its all being pumped up.
Just a thought?
Honestly do not know lol.
You seem to be pulling lots of G's!!! in acceleration.
About the only way to fix would be:
In order of cost:
Turn the boost down :no:
Trapdoor sump baffle, eg tomei,(stops some of the oil from going to the back of the sump, away from the oil pickup), stock baffle is not that effective, except for stock vehicle...
sump extension with sump baffle (deeper sump to keep oil pickup sucking oil, not air and also holds more oil)
dry sump set up, now we are talking $$$$ (race car stuff, running semi's, slicks, high HP, G's).
Feel free to add any other ideas.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
