hi all thort id put my mates car up that were building,is r30 4 door originally L20turbo manual,its taken 4 moths to get it from stock to were it is now,should be completed in 3 or so weeks,
,black top sr20
tomie rocker stopper
jjr large sump
pwr oil cooler,custom oil lines
600x300 intercoller,custom mounted in engine bay for response and battle proof
53mm alloy radiator,
high mount steam pipe manifold
garret gt2871
custom intake,custom dump,custom oil and water lines
all heater hoses,cold start,anything that can leak and cause dramas removed
3inch stainless exhaust
custom tailshaft
s13 engine cross member
was steering box,but changed to r33 steering rack,r31 steering colum custom mounted,custom power steering lines
s13 fornt hubs,nismo lower control arms,
r32 front brakes and sloted rotors
s13 coilovers
exedy heavy duty clutch
s13 gearbox custom gearbox crossmember
r200 longnose lsd
bosch 044
550cc injectors,malpasi fuel pressure reg
front faceing plenium
ford eb thermo fans
cars been completely rewired from scratch,with bare bare minimum, custom switch board mounted in center, battery behind passenger seat
auto meter gauges
velo drivers seat copy reacaro passenger seat
saas 5 point harness
hydrolic hand brake
r33 master cylinder custom brake lines
all sound deading removed,resprayed in wheel silver,
z32 afm and going with a nisstune ecu,
engine dampner
custom catch to drain back in to standard oil return
thats about it,its be design for everything to be easily and quickly fixable,motor was mounted as far and as low as posible but still able to get the gearbox bolts from the top,everything inside engine bay to allow for tapping,hopefully it going to be a good reliable weapon,
will post more pics up soon and as we get more
https://www.sau.com.au/forums/topic/378867-r30-skyline-sr20-drift-weapon/
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
fn mad! go the r30! with the sr in there itdl handle on rails! im running similar set up in my dr30, r32 xmember with 33 rack, got ne more pics/info on the rack conversion? i just want to c how u guys fitted up the crossmember.
love ur work btw
Edited by ydr030
  • 2 months later...
  • 1 month later...
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
