Hey Guys,
Im currently looking to organise a small group purchase on the BHSS Paging Car alarm (BHSS-270A i Think.
This Alarm retails for Approx: $500 australian, however it is an imported alarm (Not avaliable in Australia)
Now I have been looking for a Alarm with a Pager for awhile, and there are not many on the market. Infact I could only find 2 other models which were: Boomerang and the Steel-Mate 888a (Another import Alarm)
I was orginally going to go with the Boomerang Alarm system, however at $1000 australian I felt it did not offer enough 'Bang for Buck'
Thats when I came accross the BHSS alarm, which my friend had Installed on his Skyline. and I have found it to contain almost the Same features as the Boomerang Alarm System has.
Now on to the good stuff - The alarm system consists of the following Features:
•Keyless entry without pressing the button of remote control
•Ignition auto-door lock/unlock
•Car driver paging
•Trunk release
•Personal system set-up on the remote control,silence/shock sensor can set-up
•Wide, illuminated remote control LCD screen
•Temporary lock for remote control buttons
•Automatic diagnostics of the system's status
•Battery low warning
•Built-in central power door lock relay
•Passive door lock
•Door open sensing
•Shock sensing
•Start disable in arming status (2 Point immobilizer)
•Auto-roaming
•Passive arming
•Remote control shock settings (remote control over cars shock sensor)
•Beep sounds and icon won't flashes on the LCD screen when the system is triggered
•LCD screen illumination when the system is triggered
•Emergency panic alarm
Engine start features:
•Remote engine start
•Cold weather start- will attempt to start 3 times, if first attempt failed a 2nd attempt will occur 1.5 later. If the engine does not start again a third and final attempt will occur 2 seconds later.
Please, If you have any Information or Questions to ask, Either drop me a Private message or leave them here and I'll be happy to find out the details for you.
For note, I am purchasing these alarms off a Supplier in Queensland and Im looking to place the Order Possibly within the Next 2 weeks.
1-4 units $450
5-8 units $375
10 units $355
If the Required Number of people is reached, the Alarm will cost $355. Please Note if your purchasing outside the South East Queensland Areas and Require postage, an additional Postage fee shall be required.
Regards,
Matt
https://www.sau.com.au/forums/topic/37891-bhss-pager-car-alarm-350/
Ok, Ive had a bit of mis-communication with the supplier (read: hes ****ed me around)
Im still in talks with him, but it appears the final price will be $355 if i can get 10 people
insstead of $350 if i can get 5 people.
As you can unserstand, im pretty pissed off with being screwed around
So just letting you know there are still slots open.
twoquick - your welcome to join
yotis - dont you alreaqdy have an alarm and that?
why only 10 units? im sure the guy wouldnt mind selling more then 10.
if a spot becomes available anyway ill take one, whats the name of the place cause even if I had to pay $450 for one it sounds like a good price, you can pm me if u like
  • 7 months later...
Hey Guys,
•Car driver paging
•Trunk release
•Passive door lock
•Door open sensing
•Shock sensing
•Auto-roaming
•Passive arming
1-4 units $450
5-8 units $375
10 units $355
Regards,
Matt
have a look at Mannix too mate :)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...4504313150&rd=1
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
