Hey guys. Here's the latest offering from QStarz, the LT-Q6000 Colour Lap Timer
We'll have stock in a few weeks. Fully integrated 10Hz lap timer and Data Logger with colour LCD display in real time and built in 3 axis accelerometer. 2GB storage memory.
$449 More info HERE
Also, the Qstarz BT-Q1000eX Lap timer has now been upgraded from 5Hz to 10 Hz More info HERE
q6000.jpg2.jpg?w=300&h=133
Here's a little video recorded on our new RadCam using the Qstarz and Dashware software
I went for a RaceChrono Pro unit from http://racechrono.com.au/
I'm happy to show anyone what this thing is capable of if you're considering buying one :D
This looks awesome. Can use it for the bike as well, and easy to read screen at a good price. Even has all the australian tracks already programmed or ready to download.
Any negatives?
Looks like this will be my christmas present to myself.
Any negatives?
The new Qstarz LT Q6000 is probably better suited to motorcycles as it's completely self contained single box and requires no wiring or fitting. It just has a simple mount for attachment to handlebars.
Any negatives?
Heya a20089 :)
I'm pretty impressed with it thus far!
It does everything I need and a few extra cool things to boot.
My only possible negative is that I keep forgetting where some of the options are within the menus. Not general stuff like starting a new session, but things like adding a split marker etc I find them eventually, but to be fair, I've only done it a few times and am still learning my way around the menus. A few more runs and I'm sure I'll have it down pat, but it isn't 'iPhone intuitive', but then what is?!
I recommend having a look at these if you're in the market for a lap timer, ESPECIALLY if it's to be used on a streetable car/bike ;) The timing options are plain dangerous to your licence whistling.gif
Mark :)
  • 4 weeks later...
If you guys have a Android phone and are after a fairly accurate and cheap way of measuring lap times then download the app called "Trackmaster"
It's really useful, can add in sector times etc and export all the data to excel for graphing and comparisons. I found it to be within 0.1sec of official lap times even using the internal 1hz GPS of my Samsung mobile.
As others have said 1hz GPS updating does suck a bit, I'm looking for a cheap bluetooth GPS at 5hz but they all seem to be a few hundred each?!? So I'm very happy with my well spent $10 so far :)
Edited by SimonR32
  • 4 weeks later...
I use the GPS set up MoTeC developed for the SDL (dash logger).
You key into to the dash manager on your lappy the way points of the start/finish line of the track you're at and any splits you want.
The times, splits and laps are logged and also displayed (depending on how you want it displayed) on the SDL... so too are predictive times.
http://www.motec.com/gpsg1/gpsg1overview/
Cheap too at under $400 (from memory)... you just need to spend $15k on the MoTeC setup first!!
  • 3 weeks later...
I just upgraded my RaceTechnology dash to a 20Hz GPS... Now I just need to get to a track and test it...
The first test car we ran it in had a self ejecting cigarette lighter and the memory cards were in the wrong file format.
  • 2 months later...
I have been thinking about this myself recently- thinking of buying one of these and testing it out;
http://www.ebay.com....=item3a64068682
For that price, if it doesn't work - who cares!
I bought the latest version with the remote pickup
http://www.ebay.com/itm/Bestlap-lap-timer-infrared-ultrared-racing-track-day-V2-/200753923595?pt=Race_Car_Parts&hash=item2ebdddc60b&vxp=mtr
It works fine - lap times to two decimal places and stores each lap time for recall - no other features but fine for $60
It also works with the more expensive beacons so if any one else has a beacon at the track you can run off that instead if you want.
Third, same. Looks like a really good unit too!
There's a new firmware update out for the LTQ6000 that now allows you to use it as a rally trip meter. Used it at Targa nd it worked brilliantly. It logs and records all your stage times etc and you chancheck out speeds, track map etc.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
