hey mate if you got all this gear to go in your rs4s i hope the coilovers etc didnt come out of an rs4v cos they wont fit.
coilovers is the best thing i did to mine for better 'drivability' aka doesnt feel like your cornering in the titanic
rear is an active LSD, my rear wheels skip like a locked diff when turning close to full-lock
i actually like hicas and dont understand why people hate it so much
I am using coilovers from an auto stagea, but i'm aware that i need to swap the rear eyelet for a fork. I've got a welder so that is easy enough
Can anyone tell me what hicas lock I need to get? Is it the same as R33?
33gtr, its the auto guys who stuggle to lock their hicas (if its optioned) because their rear cradle is wider
You sure its a GTR? I cant find ANY R33 GTR hicas lock kits (which suggests they dont have hicas), but there are plenty of R33 gtst ones.
weld from eyelet to fork? i wouldnt recomend it. if they are tein just contact them and buy the lower mounts
cant find them? they are everywhere mate. type HICAS LOCK BAR / LOCKER / LOCK OUT / DELETER into ebay or just jap
my fronts also dont turn when jacked up but my rears do(rears turn in opposite directions and fronts dont move at all). when i dump clutch and light up the rears, i pull 2 strips and the rear does lock up. but i think the front doesnt turn because it has to do with the transfer case locking up
as i stated earlier, my RS4S has an ACTIVE LSD, if you guy do some research on this you'll know how it works and why the wheels spin in opposite directions with the wheels off the ground.
perhaps the fronts wont turn due to the transfer case and atessa?
ive guessed it has an ALSD, but no ALSD light on the dash like the GTRs or other equipped cars...... i always though they had a mechanical LSD, then thought maybe viscous, but now ALSD. so many people on all diff forums claim so many diff things.
ive looked under it, but it didnt look like the ALSD's that i see on other skylines. but as long as it locks up when i have wheelspin is fiiine with me
I think ALSD was an option on RWD only but could be wrong, if you dont have the lines going to your diff then it will be viscous. All stagea lsd's that I have seen were viscous only 260rs had mechanical lsd. The rs4s diff is a gtst 5 bolt center in a stagea housing, 260rs is an r32/33 (non V spec) mec diff in a stagea housing. Stagea housing is unique due to the mounting of the Altessa pump.
Ok so i just took delivery of it. Drives great except that it crunches into 4th gear, so i'll need to get that looked at
Regarding suspension, I've already got the following ready to install
Tein coilovers
Cusco Castor Rods
Whiteline swaybars
Adjustable front upper arms
Cusco Adjustable rear upper arms.
Alloy subframe lock kit
Is it worth getting a hicas lock kit? I'm not a big fan of letting the electronics decide what direction I should be going so i'm tempted to do that
This thing is a bit slow compared to our other stageas. I'm sure the 3076 i'll be installing on it shortly should resolve that issue though :)
Are Dayz S2 RS4S in black a common thing? I dont recall having seen one before
Also WHY NO CUPHOLDERS!??!! There must be a reason they decided to install a blanking plate on the RS4S' rather than the cup holders under the stereo.
I would personally steer clear of tein's, they are designed for japanese roads which are alot smoother than ours, they will be really stiff and will anoy you after a while. Ive got koni adjustables in my RS4 S and they are awesome.
Hicas lock bars are a good idea there are a few going round or you can actually lock the standard hicas up yourself.
There is a few DAYZ getting around, mine is a DAYZ.
Heres a really good one and im pretty sure when i was looking at doing mine these fit the stagea
http://www.driftworks.com/shop/driftworks-total-hicas-eliminator-kit-for-nissan.html
I live in an area with shit roads and run Tein's and they are fine. So you have RS4 rear shocks that you want to use on an RS4S? if so just change the rear hubs to RS4 you will need to press out the hicas ball joints and swap them to the RS4 hubs, not an easy job. New ball joints are a rip off $130ish ea. There are other rack ends available that delete the ball joint and use a bush, I would convert to these. Your other iption would be to buy a pair of rear R33 gtr coilovers and swap the springs & tops etc, either way will cost $$$
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
