hey mate if you got all this gear to go in your rs4s i hope the coilovers etc didnt come out of an rs4v cos they wont fit.
coilovers is the best thing i did to mine for better 'drivability' aka doesnt feel like your cornering in the titanic
rear is an active LSD, my rear wheels skip like a locked diff when turning close to full-lock
i actually like hicas and dont understand why people hate it so much
I am using coilovers from an auto stagea, but i'm aware that i need to swap the rear eyelet for a fork. I've got a welder so that is easy enough
Can anyone tell me what hicas lock I need to get? Is it the same as R33?
33gtr, its the auto guys who stuggle to lock their hicas (if its optioned) because their rear cradle is wider
You sure its a GTR? I cant find ANY R33 GTR hicas lock kits (which suggests they dont have hicas), but there are plenty of R33 gtst ones.
weld from eyelet to fork? i wouldnt recomend it. if they are tein just contact them and buy the lower mounts
cant find them? they are everywhere mate. type HICAS LOCK BAR / LOCKER / LOCK OUT / DELETER into ebay or just jap
my fronts also dont turn when jacked up but my rears do(rears turn in opposite directions and fronts dont move at all). when i dump clutch and light up the rears, i pull 2 strips and the rear does lock up. but i think the front doesnt turn because it has to do with the transfer case locking up
as i stated earlier, my RS4S has an ACTIVE LSD, if you guy do some research on this you'll know how it works and why the wheels spin in opposite directions with the wheels off the ground.
perhaps the fronts wont turn due to the transfer case and atessa?
ive guessed it has an ALSD, but no ALSD light on the dash like the GTRs or other equipped cars...... i always though they had a mechanical LSD, then thought maybe viscous, but now ALSD. so many people on all diff forums claim so many diff things.
ive looked under it, but it didnt look like the ALSD's that i see on other skylines. but as long as it locks up when i have wheelspin is fiiine with me
I think ALSD was an option on RWD only but could be wrong, if you dont have the lines going to your diff then it will be viscous. All stagea lsd's that I have seen were viscous only 260rs had mechanical lsd. The rs4s diff is a gtst 5 bolt center in a stagea housing, 260rs is an r32/33 (non V spec) mec diff in a stagea housing. Stagea housing is unique due to the mounting of the Altessa pump.
Ok so i just took delivery of it. Drives great except that it crunches into 4th gear, so i'll need to get that looked at
Regarding suspension, I've already got the following ready to install
Tein coilovers
Cusco Castor Rods
Whiteline swaybars
Adjustable front upper arms
Cusco Adjustable rear upper arms.
Alloy subframe lock kit
Is it worth getting a hicas lock kit? I'm not a big fan of letting the electronics decide what direction I should be going so i'm tempted to do that
This thing is a bit slow compared to our other stageas. I'm sure the 3076 i'll be installing on it shortly should resolve that issue though :)
Are Dayz S2 RS4S in black a common thing? I dont recall having seen one before
Also WHY NO CUPHOLDERS!??!! There must be a reason they decided to install a blanking plate on the RS4S' rather than the cup holders under the stereo.
I would personally steer clear of tein's, they are designed for japanese roads which are alot smoother than ours, they will be really stiff and will anoy you after a while. Ive got koni adjustables in my RS4 S and they are awesome.
Hicas lock bars are a good idea there are a few going round or you can actually lock the standard hicas up yourself.
There is a few DAYZ getting around, mine is a DAYZ.
Heres a really good one and im pretty sure when i was looking at doing mine these fit the stagea
http://www.driftworks.com/shop/driftworks-total-hicas-eliminator-kit-for-nissan.html
I live in an area with shit roads and run Tein's and they are fine. So you have RS4 rear shocks that you want to use on an RS4S? if so just change the rear hubs to RS4 you will need to press out the hicas ball joints and swap them to the RS4 hubs, not an easy job. New ball joints are a rip off $130ish ea. There are other rack ends available that delete the ball joint and use a bush, I would convert to these. Your other iption would be to buy a pair of rear R33 gtr coilovers and swap the springs & tops etc, either way will cost $$$
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
