Hello everyone,
As a couple of you already know the gt3076R which was only on my car for a total of about 10,000 kms has failed!
It has some slight shaft play though my main concern was The front oil seal in the turbo (piston ring seal) had eaten through the housing that they normally sit in.
The turbocharger is at garrett for warranty and I will be doing what I can to achieve a good result from the warranty.
I am entirely happy by the way the setup drove with the 3076R on there.
Now that my old turbo is dead the opportunity is here to replace/upgrade.
I have had my eyes set on the GTX3076R, I am hoping that by choosing this turbo there is only going to be improvements from the original 3076R whether its marginal or not, I hope to be buying turbocharger thats an improvement.
Alot of the info that I have seen seems to point that it needs big boost/ E85 to make it worthwhile, will I be having this same issue on my 30det or can I expect to make more horsepower across the whole graph compared to the original.
The issue that I had with the original 3076R was that from 17psi onwards the turbo needed big increments of boost to make the hp gain worthwhile (5psi for 12hp) this would be reaching max efficiency correct?
What can I expect to be different about running the GTX on my setup, i made 430rwhp on 17 psi can I expect more on that sort of boost level or are these turbo's not in their effeciency range yet.
I still haven't knocked out another contender
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__2680
atr43g3 with fnt housing
I am impressed with those results and wouldn't mind converting back to one of them due to garretts lack of support.
My engine setup is as follows...
http://www.skylinesaustralia.com/forums/topic/377415-my-2530-build-before-and-after-results/
my plan is rb30det
6boost
ext gate,
all supporting mods
GTX3076R/atr43 with .82 rear housing
cheers for your input!
is the motor built?
the engine has been running in car for about a month (if I read that correctly)
Otherwise stock pistons and rods, mls headgasket arp rodbolts and headstuds and some good tuning
This was my build thread if you need to verify http://www.skylinesaustralia.com/forums/topic/377415-my-2530-build-before-and-after-results/
I do not intend to use it for E85. pump fuel only
in that case your limit will be whatever the standard pistons can handle. reason i asked was, if its a stocker bottom end then your not gonna be able to push much further power wise and a gtx would be a waste. but in this case it comes down to how far your willing to push the standard pistons.
Bit confused by your opening post, is Garrett going to honour your warranty and give you a credit? If so, then you would choose a garrett turbo simply for convenience.
Just to confirm you are happy with how the 3076 performed before it failed? I read the sentence a few times but just wanted to make sure.
If so then I think a GTX3076 would be a perfect fit, from my reading you wont gain much at 17psi but when you increase the boost you should notice large increases in hp as the GTX turbo comes into its efficiency.
If you dont get a credit with Garrett then yes the ATR43G3 is a great option too! Or maybe a kando T67 :)
The warranty on this turbo isn't a clear cut case in terms of why it failed/what caused it. I am stuck in this process of turbocharger tennis, where between MTQ and Garrett info is being handed back and forth via email until they decide what actually happened.
As for honouring warranty not just yet but I am pursuing an outcome. They have given me the option of purchasing another turbo to get me on the road.
I am very happy with the setup. I am interested in the GTX as a bit of an upgrade from the 3076r, or even the atr43G3 with FNT.
I am balancing between the two, looking at the results that I am seeing in the hypergear thread the atr43g3 are a proven and have awesome results internally gated.
With external gate the results should even look better again.
am I right with coming to the concencus that there is going to be marginal difference on a 30det by throwing the GTX3076R on there? I would not want to go backwards by throwing one on there.
I am only going to push the motor as far as it wants to go, the old 3076R got to about 17 psi on the graph and any more than that it needed large increments of boost to make any difference to hp (like 5 psi for 10-15 hp atw)
Would I be expecting the same result from the GTX3076R until I get higher up the compressor map?
The GTX wont be a step backwards, the question is how much better will it be. On an rb25 and if you are happy to run more boost ie 22+psi then yes you will notice quite a difference. My only question is will this be the same on an rb30, is there someone who is an expert on compressor maps who can comment?
I think the ATR43G3 is also an excellent turbo and being plain bearing seems to be more reliable. I think either way you will be happy.
I guess what I am really asking is when will I be in that GTX efficiency range when it is actually going to make a difference. This gtx is such an unknown quantity to deal with. lol
Hello everyone,
The statement in bold doesn't make sense.
What oil feed line were you using to the turbo and what sort of oil are you using?
The front oil seal (compressor side) sits in a groove on the main shaft from the core.
It acts like a piston ring and sits inside a housing, stopping oil from the core escaping into the compressor.
This ring had eaten its way through the alloy housing that it sat in.
10W40 is my choice and just the standard oil line that garrett supply.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
