Gday all,
Signed up to the forums a couple of days ago but have been trolling the stagea discussion thread for over a month now and have just bought a series 2 RS4 dayz.
It's great to see a car that's still (relatively) rare on the road but with SO much information and support from enthusiasts. My background is an auto electrical trade (which i pulled the pin on after 5 years a couple of years ago) so i'm hoping to contribute as best I can to the forum. Also if anyone needs some clarification with SA road laws and motor vehicle regulations I will also help as best as I can.
I'm still a noob when it comes to Stageas but the discussion pretty much covers everything so i cant see my self not being bale to find information when I need it!. It was a big step for a Toyota enthusiast driving a JZX100/1JZ to cross over to the Nissan/RB scene but I couldn't be happier with my new set of wheels!
https://www.sau.com.au/forums/topic/379527-the-silver-clysedale/
Z32 lol...Engine out
But yeah, Its a 2 stage process to get the filter out of the Snoarer, unscrew from top, place down on X-member get underneath, place new filter on X-member, and try and thread it blind from the top
Haven't done my first service on the stagea yet but I can just imagine what the boffins at toyota were thinking when they decided on the location for the filter...
..."hmmm lets put it where only small children might be able to access it, lets make it so some how it tightens itself tenfold so that you can barely get it off and lets put it right here so it pisses out oil all over the engine mount when ever you do a service!"
so true mang, so true.
You haven't worked on a 1g-fe, now that has a hard oil filter to change. :P
RB is a walk in the park.
To the OP - Welcome aboard
Landrover TD5 Diesel
Not the centrifugal filter, the screw on Z614
/discussion
i'm sure there are some other bad ones, but the skyline isn't that bad. the fwd sr20 (at least in the n15 pulsar) is pretty bad. you can see the filter, just can't get to it without having to have your wrist at 90 degrees, while also having it up against the head. the filter on the 2000 model corollas is also a bit of a pain. it's right next to the exhaust.
best i've seen was the 3.5L v6 in the magna. it basically has a factory relocation kit. you look under the car and there it is, hanging down with nothing around it. you can get both hands on it. not contortionism, no burnt or scratched hands. no tipping oil all over the place trying to negotiate it out.
a
2008 corolla is good. Filter is directly above the sump plug and on a right angle, so absolutely no mess to clean up when you remove it or drain the oil.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
