well if you guys wanna pissup, then come to Latrobe Uni Bar Night tomorrow night... in Bundoora... half price drinks, $2 pots... and I'll be guranteed to be smashed off my googlies by the end of the night...
if anyone wants to attend, I can sign you guys in...
Its the last day of uni for this half semester, so there's plenty of booze, guys n girls... lots of american n other international students etc etc.
Tomorrow, too soon. And got guests coming over. Keep missing you at the events Shan, but I had you pointed out in a pic so I won't miss you next time.
I'll wait until James comes back with something on the bowling in the city I 'spose. Then we'll drink some Bundy mate. Ever tried a Dark&Stormy....Bundy and Bundaberg Ginger Beer in a bottle or can......MMMMmmmmmmmm.
I was at Hotham and made up 2 Litres then went an sat in a spa out in the snow with a few plastic cups. In 20 mins the spa was overflowing with snowbunnies and a few Rugby/Skiing mates. Went through 6 litres of the stuff and ran out :)
Friday arvo has the best deal @ Strike QV [city], free bowling between 5 and 6 [1 hour free bowling!]
Drink specials too: I think it was $2 pots and $3 or $4 spirits but may have just been vodka only, will check the sign again, probably today @ lunch...
After seeing some of you guys at the MAS i think we're gonna need to warn all the inoccent bystanders at the venues before you turn up.
Bowling + Drinking = Broken Stuff (mainly bones)
I'm thinking the english/irish pubs would be a good place to go to if everyone's just looking to get together.
Count me in for whatever gets organised. I'm not real fussy where it's at, as long as they've got a sh)t load of beer.
I thought Strike was $2pots on a Wednesday night?? If it came up as good as someone prev mentioned (sorry, can't be bothered going back to reply to ur post! :)) maybe we can just chill there and those who want to bowl can, and those who don't can get messy with $2 pots? Start off laughing at the ppl bowling, then those bowling start laughing at the ppl drinking later on :D
Public transport? Easy as. Melb Central station is just up the road a little, and a tram all the way down Swanston will get ya to Flinder st. So u got the pick of any train line really.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
