Hi All,
I'm quite new to this scene and now in the market for a R34 GTR. I've found the perfect GTR but unfortunately it's not a V-Spec...
Due to this vehicle being highly modified, the only thing left that matters is it has the standard mechanical LSD.
Should I steer away from this particular R34 GTR due to this fact?
FYI - It has approximately 700hp@engine and 550awhp.
Would like some opinions if it matters, if having the active LSD makes handling better, what the advantages/disadvantages are, etc..
Many thanks!
Rob.
https://www.sau.com.au/forums/topic/379872-r34-gtr-or-r34-gtr-vspec/
Having standard mechanical LSD already in the car makes it easier to maintain over active LSD(extra fluids, sensors etc)
If you really want extra grip, whack in 1.5 or 2 way diff - if having non V-Spec means installation is as simple as taking the centre diff out and swap over with aftermarket item - with A-LSD you'll need to find non A-LSD diff cover anyway.
So you shouldn't walk away from this car just cause of LSD as you have said it's modified (non V-Spec and V-Spec makes no difference whilst modified really).
All the best with the purchase, hope it's all good with the car.
Count is correct. stock vs stock. I would take the V-spec.
Modified cars are different. If the modified car suits you then purchase it. You'll more likely save money that way.
You can always sell the modified parts and revert it to stock or even purchase the V spec parts and have a sort of stock GTR with V spec upgrades, lol.
Thanks for the advice fellas.
I was under the impression with active LSD it has the ability to transfer power to the back wheels/front wheels from side to side as opposed to the mechanical LSD which can transfer from back to front only.
Any other advice based on this comment? :)
Cheers again!
Cheers again!
What is an A-LSD?
The diff is controlled via an ECU in the boot next to the HICAS ECU.
The ECU triggers a hydraulic pump that pumps a hydraulic fluid into the diff to lock it up when required.
It does this by observing the behaviour of the wheels and when it detects that one wheel has broken traction it will send power to the other wheel to compensate and keep maximum traction.
So in theory it is ment to behave like an open wheeled diff all the time and behave like a locked diff when needed.
In theory this is great however it doesn't always go according to plan.
The problem is the response time.
When a wheel starts losing traction the diff should instantly recognise it and go into action instantly without you even noticing. This would give perfect traction. The thing is, this doesn't happen.
The single wheel will break loose and in certain situations the diff will take ages to send power to the other wheel - sometimes not at all.
This causes very unpredictable "tank slaps" (Speed Wobble) when trying to go straight or when trying to slide.
- http://www.skylinesa...sd-information/
This might have been the case for the R33 GTR and Nissan might have improved it with the R34 GTR or could have stayed the same.
The theory still stands but in reality, it's different story.
I own a non V-Spec 34 with 340awkw (no idea what that equates to in hp), and the extreme amount of traction actually makes it a lil boring... Wait till you push it a lil and you will find how grippy these mofo's are. The helical diff in the non V-Spec is actually a huge improvement over the viscous units, they promote better traction and keep the rear a lot straighter whilst wheelspinning. I had mine in rwd mode for a couple of weeks after a dyno run, even with 275's you really begin to appreciate what the 4wd system does
I have a later model (01-02), which means that i get the sexy black interior, better coloured brush aluminium console, alloy pedals, and white dials. The 2nd gen R34 GTR is definitely preferable to the 1st (arguably the 1st gen vspec too). You will eventually seek your own stiffer suspension, bigger rear brakes, and diffusers that you miss out on. VSpec II's are still very expensive in Aus.
455rwhp you mean. :merli:
Not sure if the R34 is Vspec is the same - but i know it's a problem on the R33 Vspec.
What i mean by that is you cannot rebuild the A-LSD easily.
I need a rear LSD for my R33 Vspec as the A-LSD is shagged/playing up, from what I've found out i need basically a R33 GTR NON-Vspec housing and then put the Nismo diff (1.5) centre into that as the shafts or something is a different size between the A-LSD and LSD versions.
Not saying A-LSD is bad, it's taken a hiding in my car without a doubt. It's just a problem when it needs replacement.
So if the R34 is the same as the R33, then this will be a problem SHOULD the A-LSD fail. Otherwise it might well be fine for 5 years :)
I've owned both ...
* Non V-Spec R34 GT-R and a...
* V-Spec II R34 GT-R
...Rob.
And I wouldn't be put off one bit by the mechanical LSD.
Here we are - and currently F/S...
http://www.skylinesaustralia.com/forums/topic/379812-matt-and-terrys-black-r34-gt-r-for-sale/
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
