Startup up my R33 this morning, and noticed small amount of white smoke coming from the exhaust. Almost looked exactly like condensation, but to be safe, I drove it into the shed and started to dismantle.
Took the intercooler piping off. Found oil :angry:
Took the cam cover breather pipes off. Found oil :angry:
So I cleaned out what I could, put it all back together to drive down the road to a garage.
Started the car to make sure I put everything back together right, then smoke started filling up the shed.
It was coming from the exhaust/turbo side. So I thought blown exhaust gasket.
Then realised the oily mess I found before, could of been coming from the turbo and the smoke I can see is it burning.
So I removed the o2 sensor to take a quick peek for any traces of oil.
As soon as I took it off, white smoke started coming out if the hole. Not much, but looked similar to the steam you get when a kettles finished boiling.
So my question is, does this indicate that my turbo seals have blown?
Or could it be that oil is being pushed through the cam cover breathers going into the intake?
Im really hoping the seals on the piston havent blown :(
https://www.sau.com.au/forums/topic/379995-more-smoke-from-more-places/
i'm a bit unclear about the nature of the smoke you are seeing. Is it white or blueish? does it go after the car has warmed up?
From what you've described it is normal condensation. Oil in the places you have mentioned is normal.
You took the O2 sensor off while the car was running?? was it up to temp?
white smoke in the morning is usually just condensation.
black smoke is usually because its running a little rich, might puff out on WOT if you've been pretty soft on the pedal for a while?
blue smoke is the worst, that's usually oil. my GTR puffs a little bit of blue smoke out the exhaust after a power run. the tuner said its probably just the turbo seals. should be fine though, because its not too bad.
i've had smoke puff out from under the bonnet a couple times in traffic? popped the bonnet, and couldnt see where it came from so i just left it.
must've been from the turbo, or some oil that leaked onto a hot manifold and burnt off?
i did have a kinked breather hose from the catch can to the valve in the plennum, so it could've been some oil condensation being sucked through the turbo and burnt through the engine?
who know's, i've fixed the kink now and it hasnt happened again.
Nah its not steam. Ive had a blown head gasket before and its not like that.
The smoke is white. And I pulled the o2 sensor out after the car was off and smoke came out.
I tried letting the car warm up to see what would happen, but the longer i left it, the more smoke came out the exhaust.
I stuck my finger in the o2 sensor hole after i started the car for about 2 minutes, and got oil on my finger.
So oil is coming into the intake and the exhaust :mellow:
I know a little bit of oil is probably normal, but I wouldnt call this much a little bit.
And I also cleaned all the intake pipes about 2 weeks ago, so only took 2 weeks to fill up with oil.
Im pretty much certain on blown oil seals on the turbo. What do you guys think?
Ive got an rb20 turbo on the way to bolt up to see if that fixes the issue.
If it does, new turbo is in order. But if not, then Im guessing ill have to do a full engine rebuild :(
Nah its not steam.
white smoke is from coolant, is it not?? oil is blue and fuel black,
could it be a coolant finding a way into the combustion chamber?
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
