g'day all, well i finelly found a GTR in my price range, in the condition i want and with the mods i want, before plunging in and buying it though there is an issue that i dont know how big or small it is, basicly when you run into boost and rev it out (say up to 6-7 grand) and let of the throttle, the ignition cut's out and wont respond again until the key is turned off and back on, the current owner say's he reinstalled the stock airbox and a set of tomie blow off valves without retuning the car, also it's still running the stock AFM's at around 310 awka.
is this thing a time bomb, or is this a case of a good tune to fix?
the car is running forged internals, a power FC, 2860-5 turbo's on 17.5 psi (owner say's there's also maps for 19 and 14.5 psi) unkown brand 660cc injector's (part number is , splitfire coilpacks,as well as a few others pieces.
Edited by ttoks
https://www.sau.com.au/forums/topic/380162-cuts-out-after-running-into-boost/
310awkw with stock AFMs? Sounds like a hand grenade to me.
Get it checked by a professional.
would it be a case of simply getting some Z32's, or nismo AFM's and getting it tuned to fix the problem, or has the fact it's been run with stock afm's mean the damage is already done?
Yea but what do you mean by the ignition cuts out?
Pfc does not have any sort of protection???
by ignition cuts out i mean the engine will not respond, after letting off the throttle on boost at around 6-7k rpm and try to get back on the throttle theres nothing, all the dash lights, ect still work, indicators, headlights ect, turn the key off, push the clutch in and restart the engine while rolling and it's fine again until you give it another squit into boost and heavy load.
There are "maps"?
Unfortunately no there aren't. The PFC is a single map, it doesnt have dual map.
Either way as others have said, get it checked by a professional.
You are rushing into all of this in the wrong way as per your other thread.
Stop, read, learn - then do.
There are "maps"?
i dont feel as i'm rushing, i'm looking at car's, reading on here and asking questions, however i find it very difficult to learn by just reading, i cant picture what i'm looking at without actually seeing/touching/feeling it, i much prefer to see what i'm learning about in front of me, i've been lurking on here for a few months but it's only been since i started looking at car's in the flesh that i feel i'm starting to get a bit of an understanding of these beast's.
are the tomei bovs venting to atmo?
yes to atmosphere
and to the above post i havnt actually looked at to many car's, i looked at 3 yestorday, 2 r32's and a stock r33, being as i normaly work 12 hour shift 13 days a fortnight (at this time of year) it's hard to get time to drive to the big smoke to look at car's, i live in gippsland (2 hours east of dandenong)
Edited by ttoks
yes to atmosphere
OK that make it quite a long process,
I'm in perth and I got one from melbourne and one from adelaide, you might not find what your looking for in your town, I found the cost of going interstate was more than offset by the saving on the car.. but it sounds like a time thing a thumbsup.gif
310kw with -5's at 17.5psi..... it should be making more power than that, you would expect 330-350
If there really is a "19 psi map", that means the owner put 350-370kw of power through a pair of stock AFMs that will only support 300-310kw max. Sure you can tune around them slightly, but not that much
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
