danny - for sure... as soon as its mine i'll give ya a buzz to organise an alarmfor it ;)
munkeh - will give u a call today so we can meet up somewhere... will cruise in with u and say hi and have a little chat.
once the alarms in the next thing to do will be to fix that damn ugly interior lol
  • Replies 119
hahaha
yeah my skyline was a **** to keep clean... but when it is clean damn black looks good :rofl:
i'll have a spare set of rims for circuit/drifting ;) so shouldnt damage them... i can slo see plenty of tickets for parking too far from the kerb coming my way ;)
Awesome looking car narks! And like everyone else has said, yes, it's damned pimpin. I'd be guessin' you'll even be manwhoring your own ass out of the thing!
Just don't scratch it up in the first week with all that power. Mate i don't want to see a grown man cry.
spoke to J-Spec today about compliancing the car... according to ADR's if the engine in the car has australian standards and emmissions testing it is complianceable under the 15 year rule (even if the engine is not a standard or optional component in the make of car). Seeing as the RB26DETT was a australian emissions tested engine in the 1991 locally sold R32 Skyline, its OK to have in the car, and should go through compliance without any hassles...
w00t
in addition if the engine was not emissions tested in Australia and data is not available, then you have to carry out a engineers certification etc, which costs big bucks.
Wonder what would happen in the case of an RB25DET? seeing as it was never sold in Australia as a standard engine... has someone done emissions testing on em?
But its not a mini?
lol i was over that idea in less than a month :)
i went from wanting a mini to getting a bike... to getting a race/drift car to a GTR again and then this as soon as it popped up :P
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
