  • Replies 119
having worked for engineers in the past,what i have learned is that you would have to change the engine back....emissions data that was gathered for the engine in question is or at least at the time i was in the know was irrelevent when the engine had been put into another vehicle because of the weight diffrence of the 2 vehicles...also diffrent fuel tanks(evaporative systems) in the two vehicles would alter the emissions data....if the car is tuned right you could send it to ford and get a full shed test and if it passes youd be laughing...but i think it was 2500-3000 when i sent mine there about a year or so ago...this info may be incorrect on todays standards but megalla is right in saying check with an engineer
hmmm where can me or narkeh get in touch with an Engineer? (I think Dave would like to know as well) Dotars? might get onto em on tuesday.
Just rang J-spec, they said that since the engine was a Nissan RB Variant, and the car is a Nissan which came equiped with RB engines (which means things like the exhaust are still in the same position etc, and there are no major modifications to the functioning of the car), they don't forsee any problems with getting compliance on the car (which they will handle anyways). In addition they also said that since test data is available for the engine and the car, and that the car is 1988, there shouldn't be any hassles from the engineer.
Also as a side note, I've noticed that the emissions data on my car (found on the bonnet in my car) read Emission data for Nissan R32 GTR (RB26DETT). Found this greatly aamusing since I've got an RB20DE. So does that mean that I could have brought down a GTS with an RB26DETT and still have passed compliance. Mind you my car was the last RB20DE R32 to come into the country under the old compliance scheme according to canberra.
ey nark, as per the discussion before
[edited] for the mechanic report and the 30 images that he took while inspecting the car
inark- edited it for now... will explain later
hahahaha omg thats mad...
nothing major wrong with the body.... luckily i used to be a panel beater :D and that my bro is about to rent out some space for working on cars in the next month or two :D
i might need to order a new front bar (same one)... those stress cracks look a little nasty and will be hard to fix properly. Rear bar looks fine on the outside... what damage is behind it tho is a different story.
by the time im finished with it it will look smick :D
Guest INASNT
So are ya seriously getting this nackers???
If so its gonna be one of the fattest cars in vic, but driveways and and bump in gereral will be a problem coz its damn low.
BTW funky, The link to the report and pics still shows up in the email notification even tho u edited your post.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
