Hey,
I have a two door r34 that I am parting out. Car is in immaculate condition with only 39,000 ks on the clock. Has factory bilstein suspension, sunroof and nismo 2.5 catback exhaust with the in car switch to control flow and loudness. Give me a call, pm or text (at a reasonably time of day ie before 10 pm at night!) for parts availability and prices.
My number is 0422641010.
Most parts in great nick. Rear wheel has been rashed and will need respray, but other 3 are in great nick. Tyres good all round. Also has factory floor mats in great condition.
Prefer pick up from Frankston area, Vic but will post registered if the price is right.
Edited by griffonfamily
  • Replies 91
As requested, here are the photos of items. Bilsteins dont seem to have any leaks but people are welcome to inspect. Only done 39,000 ks!!. Thanks
hi is the car complianced or is it a write off as might be interested in what you have left over after it has been wrecked , ie body
thanks
will still b e interested in 6 months if it takes that long
nick - 0404099310
Sold so far:
Head unit
Clutch fan
Centre console plastics
Auto gearknob
Auto shifter surround
Ashtray
Weathershields
Windscreen Washer bottle
Wheels and tyres
Spare wheel
Jack and tool kit
Steering wheel and airbag
interested in motor inc ecu loom sensors and turbo. plus delivery to wollongong nsw 2500 if possible.
Also interested in ECU only as well.
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
Front and rear seats
A pillar trims
Hey,
Hey you still got the mud guards ???
hey mate Im after a drivers seat belt, i need one for my 4 door but im going to find out of the 2 doors are the same. if they are the same how much for the seat belt freighted to adelaide suburb 5067
thanks
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
