Hey,
I have a two door r34 that I am parting out. Car is in immaculate condition with only 39,000 ks on the clock. Has factory bilstein suspension, sunroof and nismo 2.5 catback exhaust with the in car switch to control flow and loudness. Give me a call, pm or text (at a reasonably time of day ie before 10 pm at night!) for parts availability and prices.
My number is 0422641010.
Most parts in great nick. Rear wheel has been rashed and will need respray, but other 3 are in great nick. Tyres good all round. Also has factory floor mats in great condition.
Prefer pick up from Frankston area, Vic but will post registered if the price is right.
Edited by griffonfamily
  • Replies 91
As requested, here are the photos of items. Bilsteins dont seem to have any leaks but people are welcome to inspect. Only done 39,000 ks!!. Thanks
hi is the car complianced or is it a write off as might be interested in what you have left over after it has been wrecked , ie body
thanks
will still b e interested in 6 months if it takes that long
nick - 0404099310
Sold so far:
Head unit
Clutch fan
Centre console plastics
Auto gearknob
Auto shifter surround
Ashtray
Weathershields
Windscreen Washer bottle
Wheels and tyres
Spare wheel
Jack and tool kit
Steering wheel and airbag
interested in motor inc ecu loom sensors and turbo. plus delivery to wollongong nsw 2500 if possible.
Also interested in ECU only as well.
Sold so far:
Head unit
Clutch fan
Auto gearknob
Ashtray
Weathershields
Wheels and tyres
Spare wheel
Jack and tool kit
Front and rear seats
A pillar trims
Hey,
Hey you still got the mud guards ???
hey mate Im after a drivers seat belt, i need one for my 4 door but im going to find out of the 2 doors are the same. if they are the same how much for the seat belt freighted to adelaide suburb 5067
thanks
