Hey guys, long story short, i have a spare 33 gts4 engine/5speed. Ran across rbz32.com and got me thinking about a rb30det swap into one. My only concern is bonnet clearnece with the 30 block. I know that the 25/26 are fine, but 30 being taller..?
Has anyone done this, or can find any other info besides rbz32.com that could help me out ?
I think it might be a real fun car to drive...
https://www.sau.com.au/forums/topic/380601-rb30-z32/
Sr20 is not as crazy as you think, sure it wouldn't be a ball tearer torque wise but it would do a lot of good things for handling.
The more i read about it, the more im liking. I could keep the z32 box - so no need for custom tailshafts etc, just an adapter plate and new mounts for the motor. In my opinion, most cost effective sawp for sure ! Car would be a daily, and in the hills on the weekend, so might work out really well...
https://www.sau.com.au/forums/topic/380601-rb30-z32/#findComment-6070851
There is one big problem with installing a SR20 though...
It will sound like a tractor.... Lol
haha yeah you're right.
Just put an rb26 in.
Another option is to just use the vg30 engine, that is if you want a lot of practice at pulling out and reinstalling the engine.
Putting a vg30 in a z32= engine out.
Edited by Dobz
https://www.sau.com.au/forums/topic/380601-rb30-z32/#findComment-6070944
Keep in mind this is a budget daily project only, because im low on cash, but have spare parts. Otherwise i wouldnt be choosing to modify this platform...
So at this stage its either a sr20 300 or a corolla lol...
https://www.sau.com.au/forums/topic/380601-rb30-z32/#findComment-6070993
the vg30dett is a great engine, and the weight balance and short engine length works great in the z32. I don't know why you'd go to the effort of putting a smaller engine in there, especially for a daily driver.
The vg30dett is plenty reliable ensuring its maintained properly, and is a nice torquey motor. The nvcts makes it far more pleasant to drive at normal road speeds than the rb26.
also the vg30dett is plenty cheap motor to buy too. If you're going to remove the motor anyway, it's straightforward to check all wiring connections, replace all water hoses, bypass plenum hoses and remove EGR, and then it will be at least as reliable as an rb, if not more (very few reports of oil surge etc in the vg30).
I can't see the point of this conversion, sorry.
https://www.sau.com.au/forums/topic/380601-rb30-z32/#findComment-6072967
Lack of tools, knowledge and space to work on the engine. Also maintenance costs.
With little weight reduction, the z32 is not too much hevier then the S chassis either.
https://www.sau.com.au/forums/topic/380601-rb30-z32/#findComment-6073047
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
