i have tested the vehicle on a gas bench and everything is good has a lambda reading of 1.02. and all the other gas levels are within specs. i have recently replaced the coils, spark plugs, fuel filter and o2 sensor . i have also cleaned the air fuelter and afm.
the vehicle runs fine at idle but once you start crusing along anywhere between 80 and 120 with the engine at operating temperature the car se
ems to jolt as if a really bad miss is present.
i have also noticed that the power light flashes on start up. after running diagnostis the lock up solenoid signal is missing or faulty or something cant remember exactly what it means. could this have something to do with it?
the car is a 1993 nissan skyline r33 gts with an auto transmission.
any idea would be appreciated
https://www.sau.com.au/forums/topic/380791-r33-missfire-on-cruise/
This is why I ask is it actually the engine missing or the transmission slipping/dropping out
Do the revs drop when this happens or do they stay the same/rise?
is it while cruising or while comming off the throttle? cause mine has started doing that
When you come off throttle and in gear the car should just hummm to a lower speed then it will burble when the rpm is too low for the gear. My car was running perfectly during cruise, now it lean pops its arse off ONLY during cruising. Full throttle, medium throttle etc is fine. Touching the throttle lightly to maintain a steady cruise speed sees lean popping.
500rpm drop is fair big... If it was your gearbox it would go up rather than down... Lean popping will cause your engines rpm to splutter around. If you have a big exhaust, hold the rpm with the window shut and you should hear the thud of the lean pop. My car is like. pop..........pop.....pop pop pop etc and revs bounce around and the car will jitter. Misfire sounds like a machine gun, kind of like lean pop but VERY rapid.
Only way is by sound and by AFR plots. This is misfire
its not a straight 500 drop. alot of the time i get multiples in a row adding up to 500 rpm. ill try your check next time it starts happening. what is your sugested fix for a lean pop?
I fixed my lean pop today, required a touch up in some cells in the tune. If you are running after market ECU, injectors and what not then it is very likely you will suffer from lean pop. Its common on Skylines and they require a little more fuel then stoich to run smooth.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
