Hi every one, recently I had purchased a AEM air/ fuel gauge, it comes with all the sensor and wire, but my mechanic said my front pipe doesn't have two holes to fit the O2 sensors. the alternative way is to drill another hole on the front pipe which he is not recommend me to do it. So is there any way to fit the gauge without cutting or drilling? My car is the 98 ER34 GTT thank you.
Pfft. Why would he recommend you don't do it? There's no other way, unless you want to duct tape it inside your tail pipe, that will probably work pretty well glare.gif
There's no problem cutting into the front pipe and welding the bung for the sensor. If you have a stainless pipe then you will want to cut it using a Tig welder, drill bits or hole saws will just make a mess and break in the process. It shouldn't be a problem for any decent exhaust shop, it took my mate about an hour to block off the original bung, cut the new hole, weld in the new bung, and clean it all up. That included a lot of chatting lol.
You can drill stainless just have to go on and off with your pressure as it gets stronger as it heats up.
I drilled and welded my AEM sensor in just in front of the gearbox. It's not a big job to pull the dump off and get the bung welded in. Put anti sieze on the dump bolts when you put it back together. Will help a ton if you ever have to pull it off again
Yeh it can be done with a drill, much better to blast a hole with a tig though.
Agree with everything else. If you get it done professionally, it shouldn't cost more than $50.
Is there a narrow band simulated output on that controller? If yes then Remove your narrow band sensor and replace it with the wideband.
Cut the connector off your narrow band sensor and solder it on to the NB sim output and then plug it back in to the standard loom.
Problem solved
How are you going to get the gauge to read the AFR's then?
AEM recommend the sensor be put about a metre (from memory) away from the turbine outlet, that's why I put mine where I did. Having said that, I've used an innovate in the stock location and it was fine
If you have a power fc then you can get them to turn o2 feedback off and get your tuner to tune the lean cruise values in. This is how I have mine although I've retained the stock sensor. It would mean that you could put the AEM sensor in the stock o2 sensor position
But this is if you don't think you need o2 feedback for your lean cruise
Well some widebands allow you to hook up a wire to run a signal to the ECU and then tell it to output a narrowband signal through that wire while still displaying the wideband data on the gauge. However, looking through my AEM manual, I don't think you can do that with this gauge. I know you can set it to display a narrowband signal by adjusting the rotary switch position on the back of the gauge, but then you no longer get the wideband.
Most people turn off their o2 sensor if they can. Mine is off and I'll be fitting my wideband in the stock bung. I've read more people having no issues then people having issues, on street cars. If you do high rpm driving (track, drifting, hill climbs) then move it away from the turbine.
Problem solved
This. And... there is a whole thread about this just a 2 pages back if anyone cared to look or let this guy know.
http://www.skylinesaustralia.com/forums/topic/373464-wideband-kits/
So long as you drill with a small pilot first like a 1/8" or 3mm it should go straight through easily then just open it up in steps. The weld in bung I have here required a 1" hole for it to drop in and rest on the shoulder of the boss. If you dont have that size drill bit, then go as big as you can and use a die grinder to open it up. Drill with slow speed and plenty of pressure. If you have someone handy to help they can be squirting water onto the end of the drill bit constantly so it doesnt heat up too much and go blunt.
If you need to buy some drill bits, get some cobalt bits that are made for drilling harder materials. That will make your job easier.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
