Hi guys
I'm having a bit of trouble with the rear coilovers in my M35.
I have Tanabe sustec coilovers and can't seem to get the rear level. The rear passenger side always sits 7-8mm higher than the drivers side.
Here's what I have tried to fix it.
Both sides set the same height. = out of level
Drivers rear set higher = out of level
Swapped spring assembly side to side = out of level
Passenger set lower = out of level
Loosened all arm joints to rest bush tension =out of level
No matter what I do the passenger always sits 7-8mm higher and its p*ssing me off as I can't work out why.
So, anyone have any ideas what it could be and if you have had this problem or had to adjust one side different to the other to get them level?
And it's creaking badly on that side and again can't seem to stop it.
Thanks guys.
Edited by slippylotion
https://www.sau.com.au/forums/topic/380886-m35-rear-suspension-troubles/
Interesting. If I set the spring at the same height on both sides the passenger side is about 8mm out. I dropped the passenger rear by 8mm and after letting it settle it's still about 3mm higher than the drivers side.
That said, I haven't loosened the arm bolts at all yet so maybe it has something to do with that.
So yours does the same!
At least I not going mad thinking its just my car. I've almost given up trying to sort it out.
I think the creaking noise I'm getting is from the rear swaybar D mounts. Will pull them out tomorrow and re grease them.
What heights did you run with?
Check which way the bolts are in. eg doing up one bolt on one side might make the suspension go up as doing it up on the other side might make the suspension go down. Or when you use your spanners you will notice pushing down one side and up on the other.
I have the same problem on my GTR even if I raise the lower side it just raises the other one aswell.
I havent got it sorted yet either. I put it down to a slight bent chassis from going up my steep drive way the same way every time. I need to come in the other way a few times to twist it back.
Just hit a pot hole or bump on the higher side it might raise the strut tower to the same height as both sides which will then lower your height.
Happy to say finally the car sits level and the creak has now gone. I adjusted the passenger side 10mm lower but it still sat higher. I also could not pin point that creak but my suspicions where toward the upper control arm and the sway bar.
So today when I got home I jacked her up yet again ? and it was creaking away if I lifted the hub assm up and down. I then disconnected the sway bar link to check it all out, all looked good so I put it back in. Then took it for a test drive and the creak had gone ? then when I got home the car was sitting level. I don't know how to explain it but both problems have now been sorted by removing that link and refitting it. Not sure if some how it was causing the problem 100% but it seems to have solved it and that's all I care about.
So now onto to fitting the trams shift kit this Friday/Saturday.
Nice one Paul. No workshop and a lack of confidence from me - I don't think I'll be tackling it myself any time soon. Are you getting it done Dunc?
I think I will eventually, I can get access to a hoist but I lack the confidence for this one so I'll be looking to get a workshop to do it
So what you're trying to say here... is you need Whiteline sway bars from Dale? :whistling:
No issues with mine and I have the Whiteline front and rear sway bars, Whiteline rear links, and Dale's rear mounts. Works bloody awesome!
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
