  • Replies 203
.....dammit...why do all these things happen when I have no money.....again f**k you GFC and making me loose 2 jobs this year
Alvin...you are not allowed to strip the car until next year!!!!
ahahahahahaha, if i can fix the left indicator blowing fuses today, i might just hold the car till rego runs out. lol.
otherwise, i'm butchering her today.
as for cheapie china manifolds, if he can weld the cracks, no problem!
looking good zebra, cant wait to see it finished.
you're not fussed about using cheapy china manifold and it cracking in time?
Cheers, China manifold isnt permanent, just needed to get the car going asap....Will go fancy everything down the track
hahah
If you have a aftermarket stereo in the car I can guarantee that is what is causing your issues, Headunit/amp and indicator wiring all run off the same plug under the head unit
hahah
well, yeah, headunit's aftermarket, there's some aftermarket sub in it, but i have no idea where it is. LOL.
and, issue was that the bulb's casing itself is f**ked.
zebra what happened to you rc engine store?
Its still there but nothing happening with it :(
ah that sucks
Sub will be in the parcel shelf in the middle, factory fitted 10" jobbie, sits under the same cloth covered thing-o that holds the rear middle brake light
I was thinking yesterday that there is no way this engine has 230,000ks on it.
It is way too clean inside..the water jackets look way to clean...like brand new....not a hint of stain on them...the engine has definitely been out of the car before and the sump has non factory looking sealant on it...wonder if it has had some epic rebuild and I find a set of JUN rods and pistons lol??
here is hoping.
Either way it gives me confidence to lean on it with the new turbo
here is hoping.
mine has 203k kms
I think Toyota engines in general always seem clean inside. I changed the waterpump in my IS200, inside the radiator and the water pump housing (whole cooling system) were like new. My car has done just under 200,000km.
Comparing it to my Skyline (130,000km) and Bluebird (300,000km??? ODO stopped working years ago) - Thier cooling systems seem sh*t, even with changing coolant every year.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
