  • Replies 172
Posted Images
Interesting colour. keen to see finished product :)
Pentroof style nice
Yeah it will come together nicely. its going to be somewhat of a chess board in the engine bay lol.
I actually never saw the Pentroof style before you mentioned it lol. but I do like it.
Currently just chasing up the Jun oil pump as they are out of stock until end of December.... so a part change is a possibility said to maybe look at Reimax, HKS or Nismo Oil pump.... Thanks for the suggestion on the oil pump ForceFED ;) lol.
I need to talk to Daniel-San re-Nismo oil pump actually. Reimax is probably the "best" bang for buck pending information about nismo item. :thumbsup: I'll keep you posted on my findings
Yeah I spoke to dan, he said to me the pump is 1 of the only things he is waiting on to put it back together.
I suggested Nismo, HKS, and Reimax but as my alternatives.
My concern is that the Nismo is made in the same factory as the N1s.... thus having crappy material...
I do know the Tomei, Nitto and Greddy pumps have been breaking so they are not an option.....
Edited by EAT26
It's not a matter of where. More what it's made from mate :P
Ummmm arent the Nitto pumps breaking their gears? from my understanding Dan is pressing me to get 1 made in Japan over 1 made in china like the Tomei or Nitto....
I'm just going by what Dan is telling me lol after all If he doesn't trust the pumps then they mustn't be worth the risk. I'd say the jun is still the option sadly with the month and half wait for it to be made
2 Nitto pumps are documented to have failed as of a month or 2 back. Both oil pump drive related from what I gathered.
Just caught wind of this. Have not heard anything about these failed pumps (which I normally would being an Aussie manufacturer) and if this is so I would be keen to hear about it. Can you enlighten me?
Ahhk, I remembered someone saying they were cast OS (was probably yourself that said it) Just assumed China
Going a little off topic now...but when are you guys releasing 1JZ rods and/or a stroker kit (for those of us weird people who dont want to put a 2J in their car :whistling:
Pistons not a drama at all. Would be a custom order though as not shelf stock but this can be good as exact specs required can be factored in. I do HEAPS of custom pistons.
Email me at [email protected] if you want any info.
Sorry for hijack..
Edited by NITTO
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
