  • Replies 172
Posted Images
Interesting colour. keen to see finished product :)
Pentroof style nice
Yeah it will come together nicely. its going to be somewhat of a chess board in the engine bay lol.
I actually never saw the Pentroof style before you mentioned it lol. but I do like it.
Currently just chasing up the Jun oil pump as they are out of stock until end of December.... so a part change is a possibility said to maybe look at Reimax, HKS or Nismo Oil pump.... Thanks for the suggestion on the oil pump ForceFED ;) lol.
I need to talk to Daniel-San re-Nismo oil pump actually. Reimax is probably the "best" bang for buck pending information about nismo item. :thumbsup: I'll keep you posted on my findings
Yeah I spoke to dan, he said to me the pump is 1 of the only things he is waiting on to put it back together.
I suggested Nismo, HKS, and Reimax but as my alternatives.
My concern is that the Nismo is made in the same factory as the N1s.... thus having crappy material...
I do know the Tomei, Nitto and Greddy pumps have been breaking so they are not an option.....
Edited by EAT26
It's not a matter of where. More what it's made from mate :P
Ummmm arent the Nitto pumps breaking their gears? from my understanding Dan is pressing me to get 1 made in Japan over 1 made in china like the Tomei or Nitto....
I'm just going by what Dan is telling me lol after all If he doesn't trust the pumps then they mustn't be worth the risk. I'd say the jun is still the option sadly with the month and half wait for it to be made
2 Nitto pumps are documented to have failed as of a month or 2 back. Both oil pump drive related from what I gathered.
Just caught wind of this. Have not heard anything about these failed pumps (which I normally would being an Aussie manufacturer) and if this is so I would be keen to hear about it. Can you enlighten me?
Ahhk, I remembered someone saying they were cast OS (was probably yourself that said it) Just assumed China
Going a little off topic now...but when are you guys releasing 1JZ rods and/or a stroker kit (for those of us weird people who dont want to put a 2J in their car :whistling:
Pistons not a drama at all. Would be a custom order though as not shelf stock but this can be good as exact specs required can be factored in. I do HEAPS of custom pistons.
Email me at [email protected] if you want any info.
Sorry for hijack..
Edited by NITTO
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
