Hi all, I've got an RB25DET in my car, and I just replaced the clutch with an xtreme organic HD.
Flywheel was machined, and I also replaced the throwout bearing which came with the kit.
When I put my foot on the clutch pedal theres almost no feeling. Master cylinder adjuster has been turned all the way out.
I've even bled the clutch, but I shouldnt have needed to as I didnt disconnect the hydralic line!
I'm guessing I might have to pull the box back out, but I checked everything when it went together so I dont know what would be wrong?
Looking through the dust boot that sits over the throwout fork, the clip is still sitting over the pivot ball ok.
I even swapped the master and slave from my other car to see if it would make any difference
Any suggestions?
Edited by DasBlitz
https://www.sau.com.au/forums/topic/381051-new-xtreme-clutch-in-no-pedal-feel/
By no feeling you mean its a really soft pedal that goes down like there's air in the system or it doesnt feel like your pushing it in? What sort of clutch was in there before?
I can push it in really easy, only feel some pressure when the pedal is just about on the floor.
No air in the system and no leaks.
It previously had the stock standard nissan clutch
well it seems i've even been sold the wrong clutch- ended up with one for an RB30E VL / R31
so the throwout bearing or pressure plate are probably wrong size for an rb25det gearbox and thats whats causing my problem
also means ive gotta take the f**ken box out again
Edited by DasBlitz
well thats the only explanation I've got at the moment. I'm going to have to wait until later this week when I get around to pulling the box off again.
xtreme reckon they sent the right clutch to the shop I bought it from, but the part number their website catalogue shows isnt the same as what was given to me...
Bugger that is a frickin pain. I've gotten into the habit now of comparing pressure plate and clutch plate sizes when replacing them. Obviously clutch plates will be different thicknesses but it's easier to pick up the differences when they are side by side.
Did you notice the difference in the bearings when you changed them? Strange as my freind has a r31 with rb30 and a 25 box using a rb30 clutch kit and its fine. The only difference I would of thought between the kits would be different clutch and pressure size since there flys are diff.And how did the clutch fit if it was for a rb30 flywheel?
Edited by boostn0199
Is it standard slave cylinder? If so i'd say the pedal adjustment is way out. Get it adjusted by a pro to the way you like your pedal feel before you do any(more) damage to your gearbox/flywheel
  • 1 year later...
Sorry to hijack a thread but i'm having this exact same problem on my vl and need it fixed asap so i have a car again.
Problem with mine is that the clutch wont disengage until the pedal is pushed hard against the floor and even then there is only juuust enough movement to disengage the clutch. My clutch pedal is also adjusted right out and have also swapped master and slave cylinders but that doesnt appear to be the problem. there was also zero air in the system.
Engine is a rb30, gearbox: rb30 na mf5, clutch: brand new rb25det (i think) exedy hd sports tuff single plate (the pink one).
What i decided to do is use the throw out bearing that came with the clutch which is no doubt to suit the r33gtst box and i have used this throw out bearing on the vl carrier rather than the r33 carrier as i am using a vl gearbox with the rb25det clutch.
What i did notice is that the r33 bearing had a taper which located it right centered in the hole in the pressure plate prongs which meant it sat in slightly where as the vl throw out bearing was larger in diametre and maybe slightly in height meaning it would push higher up on the pressure plate prongs and would still end up centred as the shaft would locate into the clutch hub and spigot bush. I also noticed that the r33 carrier is definately a different height to the vl although they look identical.
So anyway what i'm thinking is that the rb25det throw out bearing on the vl carrier doesnt have enough throw to disengage properly. and also the r33 TO bearing sitting right in the centre of the pressure plate may mean it needs more throw to flex the pressure plate than the vl TO bearing that sits higher up.
Anyway i'm taking the box out again and i'm pretty annoyed with myself so i want to get this right.
I'm planning on now using the vl throw out bearing on the vl carrier in the vl gearbox and hope that will fix my problem as everything will be as per factory specs except the clutch, which looks identical to the old one that was in the rb30 box and is the exact same diametre.
So what are everyones thoughts and as to what the problem could be? I would appreciate any help i can get.
I always thought R31/32/33 clutch plates, pressure plates, and throw bearings were interchangeable. Saying that I am using a clutch made for a 300ZX in my current R33.
Dumb question, but did you put the fork in properly (I think it's called that, the fork that holds the bearing and comes out of the gearbox for the slave to push)
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
