In regards to the GFX, I think that maybe having MSI Afterburner running is causing my issue, but fark, I haven't had this many problems with a game since trying to make Call of Duty 1 work with my old ATi
That's your problem right there, I've heard others have had the same problem. Pretty much all monitoring programs (eg Fraps) are causing problems with BF3.
I'm running everything on high except ultra textures, SSAO instead of HBAO and NO motion blur (I hate this setting, is it just me?), gets me a solid 75+ fps :happy:
anything above 1680x1050 the cpu differences are close to none, tests with 2 core vs 8 core cpus showed 7fps difference, when going to 1080 its something like 3fps. tested with 16gb machines and high end GFX cards.
Sooo... since I'm still using a ancient 19" standard LCD with a res of 1280x1024, can I expect close to constant 60fps with my GTX 570 on a high/ultra setting?
That would be sweet.
LOL you are running half of it on Medium? No wonder its fast!
Can ya set it to 'high' by the default selector and see what it does?
Cause you seem a lot higher and there isn't major differences between the 5850 and 6950 aside from the usual performance gains, but not over 25fps surely.. hence maybe I really am CPU fked!
I've run FRAPS without a problem?
It performs the same no matter what for me and bogs in the same places (co-op) :)
on my setup, i ran the command render.drawfps 1 in battlefield to show FPS, i got an absolute minimum of 38fps and tops of 60fps. guess the 60fps is my monitors limit, i never see any games go above 60fps.
this was with everything ULTRA, MSAAx4, AFx16, FOV 90 motion blur maxed and Vsync off. running it on 1920x1080.
not too shabby i guess.
i don't know Ash you don't see as many moving objects in campaign as what you see in a 64 person server
Ye but the servers don't have as much going on in terms of map detail compared to the campaign.
Given my FPS is higher in online even with my moderately old card.
might have to run that command and jump into a 32 player server... i jumped into the singleplayer and it was running SMOOOOOTH at 1080p, everything on Ultra.
If you hold down Ctrl+Alt+S it shows your framerate.
I get higher FPS in single player FWIW.
No worries, will try and give it a blast tonight, do some SP and some MP.
....This kills me to admit it, but as much as I've been looking forward to this, I haven't really played it at all.. I loaded up the SP, played up until you shoot the RPG at the sniper (like in the initial trailers), and haven't played more.. GOTTA STOP PLAYING WOW AND PAYDAY
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
