The only thing I'm scared of is the clutch plate coming loose, 3 of the bolts stretched so I replaced them but I'm worried the rest might let go.
I'm trying to find a picture of how the wiring gets tidied up, I took photos on my phone when i pulled it out but it crashed and I lost them all.
Edited by lilcrash
  • Replies 886
Have been reading along since you started, just unable to comment as I haven't got a clue.
Gotta say man, hats off to your persistence. I can imagine how nerve wrecking it would be to be doing the assembly of your engine for the first time, so the fact that you've pressed on with it and not payed someone else to do it despite not getting any help from anyone here is quite impressive. I do hope it all goes well for you, hopefully those dog hairs don't cause any trouble laugh.gif
Ok this is all I have left to do/buy.
Engine mount nuts for the bottom side (don't know where they ended up), set of belts, 3 bolts in passenger side drive shaft, dump pipe bolts/studs, fuel filter, fit turbo oil drain, buy some hose for the cam breathers.
So yeah should be doing my mountain run on Friday night.
Brain fart again. My car has an imobiliser. F**k im stupid. Just warmed her up and went for a 100km drive though the country side. Got home and turned her off, realized I wasn't in the garage and it wouldn't start :/. Error 21 ignition signal fault, car started 10 times with this fault.
i just did what i read on the net, warmed it up with a high idle, checked for leaks (does have an exhaust leak at the cat to fix but i can do that anytime), then headed for the biggest hills around and loaded it up and down them until i had done 100km (wife needed to wee anyway) and headed for home)
im organizing with my tuner now to get it done asap, ive got my parents car to drive anyway so it can just sit and wait until a few more km are put through it.
my wife was watching the data logging while we were driving and nothing looked dangerous. it made 1-2psi once or twice up hills. although it feels like my hand brake is on, timing out maybe, the cas is lined up with the old marks so it cant be far off, if at all.
other then that, no weird noises or rough running
When I saw the guys do the timing on my car at the shop, they removed the coil pack from cylinder 1, put some sort of a plug from the coil pack to the spark plug then clamped the timing light to that line going to the spark plug. Has to be cylinder one, any induction light will pick up the signal through the wire to the spark and flash when it does.
Bond - yeah I thought that.
Sarge - I wanted to avoid pulling that apart before I changed the plugs for the tune.
I should hear back from my tuner tonight so il see what e wants to do.
Ok just did an oil change. 115km worth of driving
There is about 15-20 big pieces of something. And the oil has a generally glittery look. Millions of tiny particles. I've kept an oil sample.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
