  • Replies 196
Posted Images
Nice effort...arent u supposed to be working or sumfin? Or just receiving from peoples tax lol....dont need to post back abt motorbikes because it sure will be alot worse than that!..:)
That's funny, coming from someone claiming to be posting on their break...which stared at about 8:50am this morning.
You also spell like a bum. Not looking good for you, dude.
you started the thread nub-cake
What is it with S13 owners????
Wtf?? Where did that come from?? Lmao I think you needed some attention sorry about that!..:)
What is it with non-nissan owners hating nissan owners? Maybe because they want one and cant have it!...:)
