What brand and weight are people using on their Skylines for the rear diff oil?
I have a '96 R33 GTST Auto. It's pretty much stock accept for high flow, an air pod, boost grounding and a FMIC. I havn't upped the boost or done any other mods to the car.
I saw this thread here http://www.skylinesaustralia.com/forums/topic/317121-how-too-change-front-and-rear-diff-oil/ where is mentions
R33 Standard rear diff - 75w-90
Am wondering if that is what people are actually using, or if they are using something else. I have no idea when the diff oil was last changed, so figured it was time I put some new stuff in.
I'm using G&W Syntrans in my auto transmission btw, which is pretty much identical to the Castrol Transmax Z.
Anyway, wondering what my options are as far as Brands for the diff oil, and the correct weight to use.
Edited by KrazyKong
75w90, 80w90, 85w90, 75w85 all 4 will do as they are pretty much sameness. As long as the gear oil conforms to at least GL-4 (GL-5 is fine too).
If i recall correctly GTST's have a viscous LSD which means the LSD component is sealed and don't need an LSD specific oil, whereas GTRs have hypoid LSDs which require a LSD compatible oil.
Standard or LSD???
If its just the standard rear diff +1 for post above. The GL rating is like a quailty rating and its just 4 or higher.
If its a LSD is more important you must use 80w-140, the reason is because its a hypoid type oil and a hypoid diff has such high pressure between the crown and pinon gears that if it was normal oil in there it would squeeze the molecules out between the pinion and crown gears and not lubricate it.
I'm pretty sure my car is a standard and not an LSD. I don't have the LSD light on my dash. Is there another way to verify what's in my car?
I went ahead and put in some Castrol Rear Axle LSX90 (GL-5) based on a friend having it in their '95 R33 GTST Series 1 Manual.
However something strange is now happening which could be a co-incidence or not. I have an Auto as I mentioned before. The gear changes are smooth, but actually moving the gear selector from "P" to "D", or even "R" is hard to do. I can feel something thumping into place and is directly related to me moving the gear lever in and out of "Park". It's very similar to when you park facing down a hill and the car rolls a fraction when you put in and out of "Park". This happens in the morning mostly, and isn't as noticeable when driving home from work. However the weather lately has been warm so I'm not sure this is a temperature related issue. Previously the weather made no difference even in cold Winters to being able to move the gear selector smoothly.
Is the gear lever/selector directly connected with the Axle oil, or only with the transmission fluid? I had brand new fully synthetic trans fluid put in the car for a service a year ago.
What should I do? Will driving the car damage anything right now? Is my gearbox about die? or did I put the wrong axle oil in. My gut feeling is I might have the wrong axle oil in my car, but right now I'm not sure what to do.
Edited by KrazyKong
Changing the diff oil might (as in just might) make the backlash in the diff slightly more noticable so that when you change into/out of gear with the auto selector, the change in direction of load via the tailshaft to the pinion/crownwheel will result in a little thump as the gears mesh up. Maybe the oil that came out was quite a thick one, or maybe it was a proper LSD oil and so had some different properties that masked the thump.
I wouldn't worry about it.
  • Like 1
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
