That price is rather expensive, you can buy a genuine Nissan N1 water pump for much less. :thumbsup:
My mate has one of these units in his old Mercedes. Makes bugger all difference in performance. But does definately help if you are constantly in traffic on a hot summer day.
https://www.sau.com.au/forums/topic/381774-rb25de/#findComment-6090411
so does properly working cooling system.
https://www.sau.com.au/forums/topic/381774-rb25de/#findComment-6091166
  • 4 weeks later...
