For R34 PFC's to work you need to have the factory keys programmed to the factory ecu, once this is done you can remove the factory ecu and the PFC will Work. Other option is to fit R32 or R33 GTR pfc with 1 and 120 deg pins swapped.
i guessing you have no injector pulse and a set timing advance of 4 dgrees? one of my customers if living this nightmare atm... runs fine on a stand alone out of a R33 but not with the R34 PFC.
There is no coding in the R34 pfc for NATS but for some reason it does require the keys to be correctley coded.... dont know why but it worked in the past.
I bought the engine from bnr34.without the immobilizer. And put it in er34...I bought a ecu pfc former use, and set it....That's what happens when you start the car:
injectors will not open...Like anything, you can run at a Ecu?
The official response Apexi....
Hello Mark,
The Power FC is like a factory ECU and will look for an immobilizer signal for an BNR34 if it is still intact in the factory harness. If you decide to bypass the immobilizer you will need to reconfigure the wiring to the ECU to do so.
A'PEXi
how to reconfigure the wiring?
I do not have an immobilizer unit ... I have a er34 with the engine from bnr34...
http://s017.radikal.ru/i403/1111/2d/dca42d66edd1.jpg
54 + contact comes from a book
oscilloscope to look that goes away and comes to 54 contact ...
also i have a genuine nissan wiring manual for this model that has the immobiliser wiring in it....i could possibly take a look at the wires and see what they do from the seimens box if needed
Please see what comes of 54 contact...thanks
Looks to me like selling the R34 PFC and switching to a R32/R33 one is going to be the only way to make it work. You arent going to be able to bypass that immobiliser circut or generate a signal to fool it.
I understand that you can use the ecu 33gtr the answer Apex wrote: If you decide to bypass the immobilizer you will need to reconfigure the wiring to the ECU to do so. It turns out you can use my ecu after reconfigure ...
How to rewire harness?
My advise to you so you dont completely f**k your car. Is call a performance workshop in your area and explain your problem and see if they can fix it, get your car onto a tow truck and get them to sort it out.
Asking a car forum how to reconfigure your harness and then you atempting if your not an electronics guru, is only going to end in tears if you wire it the wrong way and attempt to start it. You can short the power fc out quite easily and then you have a $1000 paper weight sitting there. Either get it taken somewhere or buy yourself a 32/33 power fc and do it that way.
i will take a look and post up....but from memory its the crank sensor wires you need to change as the 34 runs a diff sensor
pin 54 out of the ecu goes to the fuel pump control module.......and thats one of the wires that runs through the immobiliser box...the rest appear to be power wires/earths and antenna wires....this one may be the magic wire....my head hurts from tracing the wires on the 100000000 million fold out pages in the book
Edited by ylwgtr2
these are the circuits I found myself....
yes sorry just checked the diagram and thats correct....i must have crossed it over through one of the pages....i can also tell you that it carries some sort of funky communications signal....i have an aftermarket ecu on my car and the imobiliser did not work with it....a friend of mine that made the ecu made a device to make it work...im not sure what he did i can find out
Edited by ylwgtr2
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
