]WHITE R32 GTS-T
ALL PARTS FOR SALE IF NOT LISTED JUST ASK
FRONT STRUT BRACE $50
DRIVERSIDE GUARD $100
COMPLETE DOORS $100 EACH
WINDSCREEN $50
DOOR MIRRORS $50 EACH
TYPE M SPOLIER $50
REAR PODS $100
SEATS $150
DOOR TRIMS $25 EACH FEW MARKS
FRONT & REAR BRAKES $500
TAILIGHTS $50 EACH
REAR BAR $75
REO BAR $75
REAR REVERSE LIGHTS $50 EACH
TAILSHARFT $100
MANUAL PEDDALS $100
BARE SHELL REGO ABLE $600
R32 GTR GENUWINE 69,000K'S
PASSENGER SIDE GUARD $300
MOMO RACE WHEEL & BOSS $150
GTR WHEELS $800 NEW TYRES
GTR SPOILER $100 OR $150 WITH BOOT
TAIL LIGHTS $50 EACH
REAR REO BAR $100
IGNITION BARREL AND DOOR LOCKS $150
SEAT BELTS $25 EACH
RB26DETT APEXI POWER FC $1100 WITH HAND CONTROLLER
GTR GAUGES $100
NISMO GTR CLUSTER 320KPH $500
APEXI COIL OVERS $900
NISMO STRUT BRACE $150
APEXI PODS $200
REAR SWAY BAR $150 WITH ALL BRACKETS
COMPLETE REAR CRADLE
DIFF, DRIVE SHARFTS BRAKES $600
OIL COOLER & RELOCATOR $500 (NEEDS ONE FITTING)
FRONT BRAKES $300
HKS TOP INTERCOOLER PIPES $200
REAR GTR SEAT TOP IS FADED $125
BARE GTR SHELL AND CAN BE REGISTERED $1000
RB26DETT MOTOR AND LOOM $3000
IN THE ACCIDENT THE ALTERNATOR WAS SNAPPED OFF THE MOTOR
SO THERE IS A SMALL HOLE IN THE BLOCK
YOU HAVE TO WELD IT BACK ON WHICH WILL COST $100-$200
SEE PICTURES 69.000K'S ALSO NEEDS A WATER PUMP.
CALL/TXT LUKE 0431 391 262
TXT IS BEST ON WEEKDAYS AS IM ALWAYS ON THE PHONE AT WORK
WILL POST MOST PARTS AT BUYERS COST.
Edited by skyline_r33_panda
https://www.sau.com.au/forums/topic/382015-sa-wrecking-r32-gtr-and-gtst/
Hi,
after the following if in good comdition;
dash centre vents, window demist vents, clips that hold sill garnish, clips/screws for ecu and kick panels, internal door handles if in vgood condition, and cover over door handle bolt (on inside of door trim - passanger side) and the clips that hold the garnish down under the window wipers
Also after the plastic bits that sit inside the door and cover mirror bolts (triangle) and the metal plate that separates the rear seat to boot and boot trim
Probably a bit tricky posting some of that to Perth (wa) but what ever you have and willing to send over - please let me know
Cheers
Ps: also after the clock if it's working :)
Edited by Steve
  • 2 months later...
Hi if you still have the gtst i'm after the power steering line that goes from the pump, under the engine on the front of the crossmember then connects to the lower of the big banjo bolts of the front of the steering rack, it also has a sensor in the middle of it (I can provide pics if needed).
And would you be willing to post it to Wagga (2650) ?
Cheers
Vince
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
