im currently trying to get my R31/RB25 turbo registered in NSW. took it for an emissions test today and completely failed
using all stock parts for the emissions test bar a 3" exhaust, turbo is at 7 psi.
high flow CAT(i think this may be causing alot of the problem it may be screwed)
any advice on wtf went wrong would be great
here are the test results.
Edited by r31rb25help
https://www.sau.com.au/forums/topic/382353-rb25-failed-nsw-emissions-test/
Yep.
And why do u need an emmisions test with a standard ecu? Have the rules changed? Try another engineer
apparently i need the test because the engine im using is imported.
im thinking i should just replace the entire exhaust system on it for something with passing this damn test in mind
and i dont know what to to about it dumping about 2x the fuel its allowed to into the exhaust at the moment,
dug up my old stock exhaust and put 2 3way CATs on it after some advice from a mechanic, looks like horrid and runs horrid but it will apparently pass.
he also recommended i dont run my intercooler at all just a "straight" pipe.
He's trolling for sure. Ask him if he will pay for the new engine after yours goes bang from detonation?
why is it dumping 2x fuel it should be into the exhaust? if it is overfueling heaps then theres no way it will pass have you got bigger injectors in it or something?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
