Updated !
I spectated both runs and was quite impressed.
R33vit.. seen you stage against a loud v8 and expected you a slow pass (damn those cars are loud when your trying to listen to your own cars revs). Was quite surprised when you got to the other end in only 13.3 what changes have you done to your launching technique coz I want a 1.89 60ft :D
SLY33.. dude that car is pure horn !!! The first run I seen you do was heaps of wheelspin but you still got a great time. Then 2nd run I seen you do was even better, seems you have some awesome top end :(
After seeing both of you run and get fantastic times im wondering if thats an incentive to me to leave my car in the garage or to get back out and try n break into the high 13's
:wassup:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
