I think it is, mate. I posted a couple of months ago asking what the quickest anyone had gone with a std, non-hiflowed turbo was and the best response i got was a 12.9.
I think a second quicker is significant enough to prove a point. :) :) :)
Wasn't anything funny either - i.e. Optimax fuel, no additives, regular BCPR7ES plugs etc...
Adrian
At times i still wish i had my r33.... im trying to get the new owner to take it out to the track, running the boost it was tuned for.... hopefully within sometime he may and it will see an 11 on st tyres/ trim with no fuel additives either. My cards are on for a 11.8 @ 122-125mph but we'l see.
harun
Excellent results Adrian! Congrats :D
How much gas did you run? Still 50hp? If so, that's bloody awesome mate. Either way 11.9 @ 117 on a standard turbo is outstanding!
I can't wait to see how far I can drop my 60's with my new 275 Nittos. My Nittos have more experience than I do! They're 70-80% tread ex-9sec Keir Wilson NT555R'S :(
No honestly all sh*t stirring aside Adrian you did awesome
I was utterly amazed at the gains made from the Nitrous, sort of changes the way I look at any skyline with fmic, power fc and standard turbo as with Nitrous it has the potential for a 11 sec pass in it, you will have to get it back on a dyno soon so you can post before and after dyno sheets as i'm sure everyone is very interested
My crappy times and slip.
First time I had ever run, and was a little nervous of breaking something and having to get back to Melbourne from Heathcote.
2.61 60 ft
14.27 @ 104.97mph
Wheel spin was a bit of an issue, need more practice really. :burnout:
Hopefully get back out there soon and have another crack.
Adam
Hi Benm
I have a standard turbo running 15 pound. I think it is out of its efficiency at that boost though. Drops back to 13.5ish high in the revs. Other than that I have a greddy cooler, pod, link ecu, and a 3inch exhaust.
The car running next to me was an LS1 if anyone is interested.
Adam
I haven't been out to the drags in a while, but when it was bone stock except for 12psi, pod, 3" exhaust and a mildly slipping clutch, I ran [email protected] . Best mph was 102.09.
http://members.optushome.com.au/turbo202/C..._TC_22Sep_3.jpg
Once I've got the PFC tuned and the cooler piping hooked up, I'll be taking it out again to see how much difference the T3/4, FMIC, PFC and brass button clutch make :)
Was tempting to post up the timecards for the bike... :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
