I think it is, mate. I posted a couple of months ago asking what the quickest anyone had gone with a std, non-hiflowed turbo was and the best response i got was a 12.9.
I think a second quicker is significant enough to prove a point. :) :) :)
Wasn't anything funny either - i.e. Optimax fuel, no additives, regular BCPR7ES plugs etc...
Adrian
At times i still wish i had my r33.... im trying to get the new owner to take it out to the track, running the boost it was tuned for.... hopefully within sometime he may and it will see an 11 on st tyres/ trim with no fuel additives either. My cards are on for a 11.8 @ 122-125mph but we'l see.
harun
Excellent results Adrian! Congrats :D
How much gas did you run? Still 50hp? If so, that's bloody awesome mate. Either way 11.9 @ 117 on a standard turbo is outstanding!
I can't wait to see how far I can drop my 60's with my new 275 Nittos. My Nittos have more experience than I do! They're 70-80% tread ex-9sec Keir Wilson NT555R'S :(
No honestly all sh*t stirring aside Adrian you did awesome
I was utterly amazed at the gains made from the Nitrous, sort of changes the way I look at any skyline with fmic, power fc and standard turbo as with Nitrous it has the potential for a 11 sec pass in it, you will have to get it back on a dyno soon so you can post before and after dyno sheets as i'm sure everyone is very interested
My crappy times and slip.
First time I had ever run, and was a little nervous of breaking something and having to get back to Melbourne from Heathcote.
2.61 60 ft
14.27 @ 104.97mph
Wheel spin was a bit of an issue, need more practice really. :burnout:
Hopefully get back out there soon and have another crack.
Adam
Hi Benm
I have a standard turbo running 15 pound. I think it is out of its efficiency at that boost though. Drops back to 13.5ish high in the revs. Other than that I have a greddy cooler, pod, link ecu, and a 3inch exhaust.
The car running next to me was an LS1 if anyone is interested.
Adam
I haven't been out to the drags in a while, but when it was bone stock except for 12psi, pod, 3" exhaust and a mildly slipping clutch, I ran [email protected] . Best mph was 102.09.
http://members.optushome.com.au/turbo202/C..._TC_22Sep_3.jpg
Once I've got the PFC tuned and the cooler piping hooked up, I'll be taking it out again to see how much difference the T3/4, FMIC, PFC and brass button clutch make :)
Was tempting to post up the timecards for the bike... :P
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
