does it really matter who was driving, anyways i have the time slip that i ran 11.1 if its that important at least that can get updated, the owners of the quickest rotors and the quickest drag arnt always driven by the owner.
The old man's clutch will never be the same! ;-)
whats this old man's business mate ?
i think the boy drove it like it was stolen , his 60 ft was 1.7.. but he hit the cutout in 3rd gear , still managed 11.75 but cause he missed the gear change t.s was only118 mph , with a good gear change he would have run 11.5 -11.6 .
Hee hee! All right motor daddy, you badder than bad!
Now to convert Nick to the world of 6 cylinders where WRX spells rear vision mirror!
  • 1 month later...
  • 4 weeks later...
New personal best
MODS: k&N panel filter, heavy duty clutch, full 3 inch exhaust with high flow cat, and 9 PSI.
Temperature: 28 Deg
60ft: 2.135
E.T. 14.056
M.P.H 99.40
K.P.H 159.98
http://www.users.bigpond.net.au/rafsland/DSC01515.JPG
At SAU Drag Day today at WSID first time out shot my mouth off, said "Should do 11 sec. First run missed did a 12.18 later did a
Temp 20 C
ET 11.56
60ft 1.91
130.19mph
Result. Beat all the Skylines there. Oh I should not say that.
No I am over the hill remember. Sorry about that.
Wreckedhead I am waiting for you to turn up one day, will be fun. Will that be soon?
Will it be circuit, drag or drift, I don't mind?
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
