Hi All,
I realise this isn't a Skyline question, but I thought i'd see if anybody can give me any feedback.
My old man is restoring / racing John Atkinson's original 1984/85 Subaru RX Turbo rally car. The build date is a bit iffy as the car was a factory special build and was never fitted with a compliance plate.
He was asking me about fitting an aftermarket fuel only computer. I had a hunt around any couldn't find any direct plug in systems like the good old power fc. Does anyone know of any ? Or can anybody suggest a cheap(ish) easy to wire in fuel only computer ?
Thanks in advance,
Jeff
https://www.sau.com.au/forums/topic/382478-aftermarket-ecu-for-1985-rx-turbo/
I used to own one of those (street version)
had it dropped on 17" simmons - looked fairly tough.
. mate of mine used microtech on one . the thing would never start the second time around. (this was 10 years ago - they man have gotten better since.)
if its a rally only special with full cage post up some pics.
ECU - autronic or motec. may as well make use of the antilag option :)
Cheers - thanks for the info guys.
Yeah I'll take a few pics next time i am over in Victoria. Actually come to think of it we are doing the BLCC Xmas Autcoross - i'll take some action shot then.
Thanks again,
Jeff
well, i can pretty safely say that any info u want or need, PM me, i had a pretty ballistic 430whp ea82-t powered 1985 rx turbo leone. I ran a haltech and still had the stridubutor. we used a an early honda civic optical internals in the original housing so it would work properly with the haltech. i think it was an old F10-x from memory. Oh, and buy a few headgaskets and lifters, youre gonna need them. If you want to get serious with it, i have the numbers and drawings for a set of custom forged pistons we had by SPS in SA, from JE blanks and we got a set of Rods made by manely. Any sort of boost increase over 12psi will require an Oringed block. For a cheap and easy upgrade the early liberty RS turbo's are a bolt on affair, and much larger than standard. You can get 280zx injectors for a drop in upgrade too :)
Cheers, Allan
Cheers, Allan
Far out - that sounds serious! The engine is forged build already (o-ringed, forged pistons, rods, etc etc etc etc) I think from memory it runs 14PSI, also runs a custom built clutch, clutch fork and thow-out bearing, along with an adaptor plate into a liberty gearbox as it kept blowing the standard RX turbo box (even with oil coolers & pumps everywhere lol) He mostly uses it for Autocross events now, as being a factory special built car it's a bit of history that shouldn't be crashed lol...
Thanks so much for all the info, i'll pass it along and keep in touch...
Jeff
  • 4 weeks later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
