was just wondering what times you fast guys are rattling out over there now as its been a good couple of years since ive run anything at those track and at the time 1.43 on a radial at the island and 1.16 and sandown and 63 or 4 s was the goods at calder, whats the goods these day
Those times still hold true for a fast GTR. Problem is there aren't any track only GTRs running around Vic...Most are fast street/track cars which are still 1-2 sec off the times you posted as full weight street cars on semis
Fair enough. As per Roy's post above my car is a full weight street spec car (no weight removed - not even the back seats, aircon, stock brakes etc etc)...all I do is bolt semis to the thing. At PI I have done a mid 1:44, Sandown a mid 1:19 and Calder a 1:06 (although to be fair I haven't had a real crack at Calder - car is capable of a 62 IMO).
  • Replies 67
anything under a 1.46 or 7 is fast on a semi there in a road going car, the last time i ran there in a road car i think we ran a 1.41 on a 265/640/18 slick but in full road trim drive there drive home, so 1.44 on semi is sensational, there was a guy running at the time called marcov or something like that from further north running in the 43,s i think too at the time in a 32 gtr
Back to the original q...do I think my car (I know its not a dedicated track car) would be faster in 2wd? On face value, I would say no as in slower corners the car has way more exit speed than 2wd cars. Also when the car does break traction mid through a corner the awd allows me to keep on the throttle. This was particularly evident on my 44 at PI as my right rear semi was effectively bald. Around left hand corners like lukie heights the car would break away and I had the confidence to keep on the gas as the awd would pull me out of the corner. With the tyres going off like this a 2wd car (even if it were lighter) would never be able to pull a time like that.
A good comparison would be my battles with Russ's track gtst during 2010. My car was a full weight (as described previously) 33 gtr with 280kw at the rears. Russ's 32 was stripped with about 250kw at the rears (roughly...Russ could quote a more accurate power figure). IMO the slight power advantage of mine is offset by the weight difference which leaves a fairly good comparison between the 2wd and 4wd (before anyone complains I know there was a fair bit of chassis, suspn geometry diff between the 32-33)....oh and I was running slightly wider semi's as well. At the end of the day we were neck and neck at most tracks with not a lot splitting us. However when tyres were worn or the track was damp the 4wd was on top.
back in 2010 I was on 245 rubber, 225-230kw. And remember thats an RB20 230kw haha. They were good times hey Ant!
Also it wasn't that 'stripped'. no rear seats but had a half cage. air con out but that's about it. I was regularly driving to track days then.
My opinion.. Ant's and my cars were neck and neck and we both had a ball in the cars we chose, 2WD or 4WD. I'm RWD biased so I think Ant's car would be faster without 4WD but only on some tracks, not all. For the weight penalty you need to have more grip, power down (not all GTRs get front wheel power down with worn transfer cases), brakes etc, so a RWD will arguably make the times 'easier' and cheaper.
Before Ant and I upgraded things in 2011 we were both doing roughly 34-35's at Winton, 47-48's at PI, 24's at Sandown.
Conclusion.. If you want your GTR to go as fast as a GTSt add more rubber, brakes, power and cash haha. :laugh:
I got a bite :)
Forget this silly argument. Buy a GTR to have a GTR.
If u want a light RWD that overtakes GTRs round the track, then get a Silvia. JET200 weighs 1100kg and makes 350rwkw.
Drove around GTRs with 400 and ran sub 1:40s at EC
If you know how to build and drive a well set up race car, RWD is perfectly fine. But if u want to win WTAC, look at the previous leaderboards......
  • 3 months later...
Having owned (until recently) a bone stock gtst and currently a stock suspension wise gtr IMO the gtst wins hands down in the handling department.
Both vehicles had/have rubber upgrades only, With the gtst it was a simple matter to dial the understeer out on tyre pressure alone. a couple of pound difference was all required to turn the handling to neutral verging on slight oversteer (ideal imo)
The gtr is a freakin plough in comparison, No amount of playing with pressure has any effect whatsoever. It would take some handy spenshun mods to get the gtr to turn in like the gtst.
Wet roads are a whole nutha ballgame, the gtr owns the road on a wet track. Both cars are great to drive in their own way but the gtst is far more nimble and agile up to a point than the gtr as a street driven daily. The VCT also makes it a more responsive package to boot.
My black ERD gtst is a good example of a highly modded gtst, it gives nothing away to gtr's of a similar ilk, Some are faster some arent, (I aint sennaesque in my driving ability)
I still rate a 33 gtst very highly as a user friendly tuneable all round package. . .
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
