Im a fan of the 4-door style taillight and want to put them on the back of my coupe. Just wondering if anyone else has done this conversion, and if so how.
The coupe bootlid looks to be wider so i was thinking i would have no choice but to use it and get it cut to fit. Just trying to find out what i can before i attempt this, i already did a search but only found stuff about putting a coupe rear on a 4 door...i want the opposite ><
any help or pics would be great, cheers guys
(P.S. 4 door rear ftw)
Matt.
https://www.sau.com.au/forums/topic/382837-change-coupe-rear-end-to-4-door/
Its not the 4 door i like so much, just the coupe taillights i dislike...
And I did not buy a four door because the car I found for sale was a coupe, And for what I got with it and what I payed for it I couldn't say no.
Besides, I still have a full 4 door body kit from my previous 32 and I have a set of taillights on there way to me atm.
I am determined to make it happen, Just thought someone else was bound to have done it and could give me a few pointers or something along those lines.
If you happen to find a way to do this ill kindly swap my 4 door rear for your coupe rear :whistling:
Heres info for the other way round, if the 4door needs metal to be cut away for the coupe lights to fit i guess that the coupe would need a bar welded in to hold the tail light in ??
Got my 4door taillights today and ripped the rear end off the coupe so I could trial fit and see how much work was involved.
Good thing is its not as much as i had thought, definitely doable. Cut away a bit of steel and drill some holes to fit the lights in and then weld some steel on to the boot lid and shape them to the lights.
The 4 door rear bar I have is almost going to bolt straight on, just needs to be cleaned up and some small adjustments.
Will post pics shortly of the trial fit.
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
