Give me a couple of weeks.
Just fitted 4000 series front and rear to my R32. Running EBC ceramic RS fnt and GS on the rear
I'll keep you all posted
(BTW) I ran EBC V2 RS on OEM rotors for TT03. The ceramics work better at low temps for sure. And initially feel stronger. Remembering that brakes are personal. In the early carbon days on the superbikes, guys would run carbon on one side and conventional on the other... prefering feel to outright performance.
TT
They feel no different than standard rotors, however on a track they will last longer than standard rotors due to better heat dissipation.
I've been using DBA4000 for about 9mths now with RB74 front pads and COMP2's on the rear. This RB74 pad is where the real difference in stopping power is :D
Hi XEQTOR, we use DBA rotors on all of our cars, road and race. The pads of choice are Hawke Carbotic, in the Blue compound. The alternative is Performance Friction Carbon Metallic, in the 01 compound.
I have got DBA4000 slotted rotor F&R on both the R33 GTST and GTR and have found them quite good.  A noticeable difference on the time taken to induce fade.
i had them on my soarer and they vastly improved stopping especially from high speed. They were Very fade resistant and i'd definately buy them again :D
Better heat dissipation.... There is nothing wrong with standard rotors at Symmons Plains, a renown brake tester. The Japanese use good steel and it is well cured by the time we see em (120ks in 10 years)
Trouble is with some of the local product is we get beer cans car doors and all sorts in the mix... end result :D
Anyhow, I've bought the dba sales pitch and we will test, for five days 2500ks
TT
i changed from stock rotors with bendix metal kings to dba4000's with ebc greens, and it made a very noticeable difference (note that my std rotors were 1mm undersize). Very initial bite is low, but they only need a small amount of heat before the bite becomes real positive. Only prob now is the std brake lines. I get fluid fade and/or line swelling after a good thrashing so im getting some braided lines very soon. am told they will make a world of difference, and that if i was even considering track work, i should most definitly get them fitted!
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
